Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Extrude cut not cutting it!
24 REPLIES 24
Message 1 of 25
7007 Views, 24 Replies
I was trying to cut into this body but it doesn't seem to work.
I'm not sure what the issue is as I've done this same thing before and it did work.
I attached the fusion f3d file.
Any help or insight would be appreciated.
Thank you.
Thank you.
Labels (1)
24 REPLIES 24
Message 2 of 25
Phil.E
Phil.E
Check the "objects to cut" list in the Extrude dialog. I don't see any issues with the file you attached, so perhaps in your workflow that body is not included in the cut list. I can't reproduce any problem here.
Phil Eichmiller
Software Engineer
Quality Assurance
Phil Eichmiller
Software Engineer
Quality Assurance
Message 3 of 25
in reply to: Phil.E
Hmm, I actually looked at that section before and Body 5 (the body I was trying to cut into) was indeed checked yet it didn't work.
However it seems that it does work now. Maybe me restarting Fusion 360 had a hand in it.
It's very odd but it seems fixed for now.
Thanks for the help.
Edit: I tried doing the same thing on another side and it had the same issue. I saved and tried it again and then it worked so something weird is going on for sure.
Edit: Now saving didn't work either anymore. Hmmm
Message 4 of 25
g-andresen
g-andresen
try it this way:
Why > ?
günther
try it this way:
Why > ?
günther
Message 5 of 25
in reply to: g-andresen
I tried the way you're showing but also no success. I also checked the "Objects to cut" section but that seems to be all in order yet it's still not doing what it's supposed to. (Or at least I think so)
I'll include another screencast just to confirm.
Message 6 of 25
g-andresen
g-andresen
just tested > extrude from backside
günther
günther
Message 7 of 25
I'm not sure what you mean.
Message 8 of 25
jeff_strater
jeff_strater
I think there is a bug here.  I can reproduce it, but the results are variable.  When it fails, going into the parameters dialog and adding a "-" to the distance makes it work OK (though you cannot do this in the dialog).  So, the sketch seems to be confused about its extrude direction in some way.  I'll log a bug on this.  Here is a video of times when it works, and other times when it does not.  Some of the profile curves seem to be causing the issue...
Jeff Strater
Engineering Director
Jeff Strater
Message 9 of 25
davebYYPCU
davebYYPCU
Failed 1st time for me too.
Extrude with a drag on the blue handle an exaggerated distance or by selecting All,
both worked, here.
both worked, here.
Message 10 of 25
jeff_strater
in reply to: jeff_strater
jeff_strater
I found that this profile, in particular, is a problem:
selecting that one always goes the wrong way.  Other profiles seem to be fine.  Bug.
[edit] the Fusion bug is FUS-75757
Jeff Strater
Jeff Strater
Message 11 of 25
Thanks for tracking the issue down! @jeff_strater
To give some context to everything (I don't know if this will help but maybe it will)
I used the Voronoi Sketch Generator to generate the sketches
My settings for the sketches generated are:
Curved
30 cells
10 iterations
140mm
140mm
75 % scale
Once generated I did have to move them into place by rotating and then moving them to the correct position.
From that point on I would do Extrude Cuts like shown.
Here's the link to the Generator:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1006119760063675415&appLang=en&os=Win64
For now I'll mark it as resolved.
Curved
30 cells
10 iterations
140mm
140mm
75 % scale
Message 12 of 25
k.asmena
k.asmena
Community Visitor
Community Visitor
Its a display glitch. Make a cut, it will show as extra faces on body, but after restrting fusion it shows as cut.
Message 13 of 25
rampantwolf
rampantwolf
Observer
Observer
3 months later, this problem still persists in the latest Fusion 360 release. My Fusion 360 is up to date and I have restarted my computer several times. I'm running into a similar glitch when doing a simple circle extrude cut out of a solid piece. Sometimes it works, sometimes it doesn't. Pretty frustrating that one of the most basic 3D CAD parametric modeling functions doesn't work in a predictable AND EASY way. Hope this get's some urgent attention from the developers as this bug is rather crucial to the UX of Fusion 360. thx
Message 14 of 25
jeff_strater
in reply to: rampantwolf
jeff_strater
can you supply some relevant supporting data?  I have not heard any other reports of Extrude Cut not working in any general sense.  Please share a design that shows a problem, along with info about what profile you are selecting, distances for extrude, etc.
Jeff Strater
Jeff Strater
Message 15 of 25
bpfouche
bpfouche
Community Visitor
Community Visitor
I have a similar case that I have isolated in the attached file.
In sketch named "grooves" (second sketch), change d16 from 5.35 mm to 5.2mm. From that moment the cut operation into the picatinny/stanag rail doesn't work. More exactly, if after this change the file is exported as a STEP file in read into a 3D slicer (I use Bambu Lab Studio) then the file appears to be correct. It is a display glitch inside Fusion 360 but quite a painful one because it breaks the design flow.
   Bernard
   Bernard
Message 16 of 25
g-andresen
in reply to: bpfouche
g-andresen
something wron g with Body 1
With a copy of the body it works.
günther
günther
Message 17 of 25
samuel.templeUCPAE
samuel.templeUCPAE
Hello @bpfouche
I am the QA working on the Extrude feature.
Would you be able to add a screen recording of the issue? I am not able to reproduce the issue on my machine as the cut appears to work correctly after changing the dimension.
Fusion 2.0.19725
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
Hello @bpfouche
Fusion 2.0.19725
Samuel Temple
Message 18 of 25
g-andresen
Yesterday I was able to confirm the described behavior and offer a workaround.
Today, however, the “error” no longer occurs when the original file is opened several times.
günther
günther
Message 19 of 25
samuel.templeUCPAE
samuel.templeUCPAE
Hey @g-andresen
Thank you for your response.
I did a lot of playing around with it today but i just couldnt reproduce the issue.
If anyone can reproduce the issue and record it, please so share it here as it will help me and the development team hopefully find the cause.
Samuel Temple
Hey @g-andresen
Samuel Temple
Message 20 of 25
g-andresen
Have a look at this thread with  my post 4 and in this one in the German forum
günther
günther
