Fusion Support
Error
3 REPLIES 3
tom.r2TZDK
307 Views, 3 Replies
Error
I keep getting this error. Can someone please tell me what i can do to solve it.
Fusion 360
Copy this message using Ctrl+C:
C:\Users\Tom\AppData\Roaming\Autodesk\ApplicationPlugins\DirectName.bundle\Contents\thomasa88lib\events.py failed:
Traceback (most recent call last):
File "C:\Users/Tom/AppData/Roaming/Autodesk/ApplicationPlugins/DirectName.bundle/Contents\thomasa88lib\events.py", line 142, in catcher
func(args)
File "C:/Users/Tom/AppData/Roaming/Autodesk/ApplicationPlugins/DirectName.bundle/Contents/DirectName.py", line 350, in rename_command_destroy_handler
ui_.activeSelections.clear()
File "C:\Users/Tom/AppData/Local/Autodesk/webdeploy/production/df098dc22bdb0532c3884db0a2d6182c8f8678de/Api/Python/packages\adsk\core.py", line 15655, in clear
return _core.Selections_clear(self)
RuntimeError: 2 : InternalValidationError : selecCmd
OK
3 REPLIES 3
JeromeBriot
in reply to: tom.r2TZDK
@thomasa88 I think this one is for you 😉
thomasa88
in reply to: JeromeBriot
@JeromeBriotyup. The add-in withstood for 3 years without any updates! I thought no-one was using it, but I have gotten several error reports 😅 . I have updated it to use newer code, so the error message should say the add-in name the next time. 🙂
@tom.r2TZDKThe error comes from the DirectName add-in. I have published a fix on Github. Please see the information in this message: https://github.com/thomasa88/DirectName/issues/5#issuecomment-1507468537
You can either get the new version from GitHub or disable the add-in.
It will take a few weeks before the fix reaches the Autodesk App store.
tom.r2TZDK
Thanks. I thought it was a add on problem so i deleted the folder. Now i can reinstall them. 🙂
