When i 3d print a design to Simplify3D or Cura and i sent the output to a 3D Print Utility, everything works just fine.
However when i output to a STL-file and import that file to S3D, it crashes. Cura gives me a: invalid file.
Is there any reason why i cant import the STL-file?
I attached a sample STL-file which is giving problems.
@Anonymous wrote:
....However when i output to a STL-file ....
Can you File>Export and then Attach the *.f3d file that is returning this stl file? (the file appears to be completely empty)
Attached the simpelest bracket i made for a P4 panel.
I have to mention again, if i 3D print this to a 3D Print utility it imports into S3D and Cura flawless.
I had no trouble creating valid stl file from your *.f3d file.
Can you create a Screencast Recording showing how you are Exporting the body to stl?
Hmm... I am able to export an STL from this model, and re-import it into Fusion OK. Fusion does crash if I import the STL you attached above, though. What settings are you using for export?
Ok guys, i figured this out (yeahhh)
It seems i was exporting the wrong way?
If i use Make->3D Print and didnt print to a 3D Print Utility, it creates a STL-file, but was giving me errors like i mentioned.
But when i right-click on a Bodie and save as a STL-file, everything works ok.
The Format->Binary option in jeff.strater's post made me dig into this further.
Thank you all for your help in this 🙂
