Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Error in STL-files?
5 REPLIES 5
1148 Views, 5 Replies
Error in STL-files?
When i 3d print a design to Simplify3D or Cura and i sent the output to a 3D Print Utility, everything works just fine.
However when i output to a STL-file and import that file to S3D, it crashes. Cura gives me a: invalid file.
Is there any reason why i cant import the STL-file?
I attached a sample STL-file which is giving problems.
Tags (1)
5 REPLIES 5
TheCADWhisperer
@Anonymous wrote:
....However when i output to a STL-file ....
Can you File>Export and then Attach the *.f3d file that is returning this stl file?  (the file appears to be completely empty)
in reply to: TheCADWhisperer
Attached the simpelest bracket i made for a P4 panel.
I have to mention again, if i 3D print this to a 3D Print utility it imports into S3D and Cura flawless.
TheCADWhisperer
I had no trouble creating valid stl file from your *.f3d file.
Can you create a Screencast Recording showing how you are Exporting the body to stl?
jeff_strater
Hmm... I am able to export an STL from this model, and re-import it into Fusion OK.  Fusion does crash if I import the STL you attached above, though.  What settings are you using for export?
Jeff Strater
Engineering Director
in reply to: jeff_strater
Ok guys, i figured this out (yeahhh)
It seems i was exporting the wrong way?
If i use Make->3D Print and didnt print to a 3D Print Utility, it creates a STL-file, but was giving me errors like i mentioned.
But when i right-click on a Bodie and save as a STL-file, everything works ok.
The Format->Binary option in jeff.strater's post made me dig into this further.
Thank you all for your help in this 🙂
