I'm having alot of problems with drawings. It looks like each time I update a model with some new component, the drawing do not update correctly and often draw in different position the lines and the shades, at screen and to the PDF.
Someone have the same problems?
Solved by carl.j.barker. Go to Solution.
Thank you alot Carl, after one week of trouble and 2 tickets where the support team can only tell me to update the graphic card, it need a user to tell me this stuff. Thank you alot again Carl, you solve my day (hopefully). 🙂
