Fusion Support
Move a part of an existing iges file runs into "An existing fillet or chamfer could not be detected"
1 REPLY 1
luc41923
208 Views, 1 Reply
Hey there, i need some help. I got a iges file from thingiverse: https://www.thingiverse.com/thing:4337337
But i need to move the platform like 2cm to a side while the legs stay where they are right now. 3.png
But if i mark this "platform" and move it to one side, i'll get
Error: An existing fillet or chamfer could not be detected.
Try suppressing or deleting existing fillets/chamfers before attempting the operation.
Can someone explain me step by step how i can achieve this and move the platform x mm or x cm to a specific side where the legs stays where the are right now? To be more clear, i want to move the platform to the right, so drill holes above line up with the drill holes at the bottom + 5mm.
So if you see the model from the side, it should look like this:
1 REPLY 1
jeff_strater
in reply to: luc41923
I assume that you are using Move Faces for this.  Move Faces works in kind of a 3 step process:
  1. temporarily remove fillets and chamfers
  2. move the faces
  3. reapply the chamfers
it does this to try to preserve the design intent of those fillets/chamfers, and because the face move is easier on simpler geometry.  The error is indicating a problem in this process.  So, you can do like the error says and try removing the chamfers yourself (using Delete), and see if maybe you can do the Move Face operation, then manually re-apply the chamfers.  No guarantee that this will work, but you might be able to get farther this way.
Jeff Strater
Engineering Director
Technology Administrators
