Crash during sktech on Windows 11
adamo000
adamo000
While working on the sketch, the whole monitor got black and after that, the Fusion froze and crashed.
The situation is annoying because I can't design anything from start to end..
This has been happening for sure since mid of the April and the recent update didn't resolve this issue.
I have reported a few incidents after the Autodesk Error Report window had been opened.
My setup:
Windows and drivers are in latest available versions.
Windows 11 Home 26100.268
Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.81 GHz
16GB of RAM
Nvidia GeForce GTX 1060
4k Display connected to HDMI port.
Screenshot of the latest crash
If some dump files are required I added them here as a attachement.
Marco.Takx
Hi @adamo000,
Have you checked this article?
Workspace-view-flashes-goes-black-or-blank-white-when-opened-a-design-in-Fusion-360
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
adamo000
Dear @Marco.Takx, thank you for your reply.
I performed some tests with a different setup and the one that gave me a stable workspace was:
- DirectX 9
- Limit effects to optimize performance
I will spend some more time testing the combination, and if the error is no longer valid, I will give the final comment.
Thank you!
