Fusion Support
Fusion 360 Slow Performance When Computing Faces
4 REPLIES 4
ThePieMonster
209 Views, 4 Replies
As you can see via the attached video, the performance is quite slow when attempting to perform "remove faces" operation.
Any way to improve performance of this simple part?
4 REPLIES 4
Is the geometry imported, or was it created natively in Fusion?
If it was imported, could you share the original file you imported?
It was a imported design. When re-creating the part in Fusion 360 it performed better.
I since deleted the original which was a 8x12cm but I attached a smaller version that is basically the same thing.
I don't experience any slowness with the model you attached. Removing faces (auto repair) functions instantly.
Its a different model in this case, the other one was geometrically larger. If I encounter it again I will post back here.
