While working on the sketch, the whole monitor got black and after that, the Fusion froze and crashed.
The situation is annoying because I can't design anything from start to end..
This has been happening for sure since mid of the April and the recent update didn't resolve this issue.
I have reported a few incidents after the Autodesk Error Report window had been opened.
My setup:
Windows and drivers are in latest available versions.
Windows 11 Home 26100.268
Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.81 GHz
16GB of RAM
Nvidia GeForce GTX 1060
4k Display connected to HDMI port.
Screenshot of the latest crash
If some dump files are required I added them here as a attachement.
Solved by adamo000. Go to Solution.
Hi @adamo000,
Have you checked this article?
Workspace-view-flashes-goes-black-or-blank-white-when-opened-a-design-in-Fusion-360
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Dear @Marco.Takx, thank you for your reply.
I performed some tests with a different setup and the one that gave me a stable workspace was:
- DirectX 9
- Limit effects to optimize performance
I will spend some more time testing the combination, and if the error is no longer valid, I will give the final comment.
Thank you!
