Announcements
compute time takes too long
an18211821
an18211821
I have a 8th gen i7-805g with Radeon RX Vega M GL graphichs, 16gbRam ,with nvme SSD
when i design for example a pattern i have to combine it with drinking coffe because it takes too long for each task.  When the program stops responding , i check the task manager and only 25% of the CPU is in use and GPU below 10%. what could  be the reason?
Does is not use the internal graphics for the calculation so its a matter of internet speed? Or is multithreating not well designed (with result one logical core having a lot of load-task to handle and many data to be exchanged between ram and cache memory )?
g-andresen
the reason:
the Fusion sketch solver doesn´t like such complex sketches.
Note: never use patterns in sketch mode. Instead create only 1 element in your sketch and then 1 feature.
Finally you can pattern this feature.
günther
an18211821
its a pattern of of 2 sketches repeated 50 times.
its more then 45 minutes that the programm stoped responding and i wait because i am afraid to loose a lot of steps
g-andresen
please share your design to take a look.
günther
MoshiurRashid
Hello
It is happening because of the sketch patterns. The good way is you create a feature with 1 sketch then use the Feature Pattern to do the job. This will give you less complexity to complete the shape.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
