Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
compute time takes too long
4 REPLIES 4
an18211821
973 Views, 4 Replies
I have a 8th gen i7-805g with Radeon RX Vega M GL graphichs, 16gbRam ,with nvme SSD
when i design for example a pattern i have to combine it with drinking coffe because it takes too long for each task.  When the program stops responding , i check the task manager and only 25% of the CPU is in use and GPU below 10%. what could  be the reason?
Does is not use the internal graphics for the calculation so its a matter of internet speed? Or is multithreating not well designed (with result one logical core having a lot of load-task to handle and many data to be exchanged between ram and cache memory )?
Labels (2)
4 REPLIES 4
g-andresen
in reply to: an18211821
the reason:
the Fusion sketch solver doesn´t like such complex sketches.
Note: never use patterns in sketch mode. Instead create only 1 element in your sketch and then 1 feature.
Finally you can pattern this feature.
günther
an18211821
in reply to: g-andresen
its a pattern of of 2 sketches repeated 50 times.
its more then 45 minutes that the programm stoped responding and i wait because i am afraid to loose a lot of steps
g-andresen
please share your design to take a look.
günther
MoshiurRashid
Hello
It is happening because of the sketch patterns. The good way is you create a feature with 1 sketch then use the Feature Pattern to do the job. This will give you less complexity to complete the shape.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
