- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a 8th gen i7-805g with Radeon RX Vega M GL graphichs, 16gbRam ,with nvme SSD
when i design for example a pattern i have to combine it with drinking coffe because it takes too long for each task. When the program stops responding , i check the task manager and only 25% of the CPU is in use and GPU below 10%. what could be the reason?
Does is not use the internal graphics for the calculation so its a matter of internet speed? Or is multithreating not well designed (with result one logical core having a lot of load-task to handle and many data to be exchanged between ram and cache memory )?
Link copied
