Fusion Support
Cant download fusion 360
6 REPLIES 6
metalman123456123
506 Views, 6 Replies
The trail link is giving me a 404 error
6 REPLIES 6
in reply to: metalman123456123
I am getting the same error also.
017-08-08 14:38:00,230 - Dummy-1 - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-08-08 14:38:00,250 - Dummy-1 - adsk.dls.streamer.process - INFO :: Primary app is 73e72ada57b7480280f7a6f4a289729f
2017-08-08 14:38:00,251 - Thread-44 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Exception_urllib.error.HTTPError" args: ['73e72ada57b7480280f7a6f4a289729f', '2.0.3174']
2017-08-08 14:38:00,251 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Exception in Update HTTP Error 404: Not Found
2017-08-08 14:38:01,197 - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2017-08-08 14:38:01,198 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2017-08-08 14:38:01,198 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2017-08-08 14:38:01,198 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2017-08-08 14:38:01,198 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000013E27015978> #
2017-08-08 14:38:01,198 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2017-08-08 14:39:53,579 - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-08-08 14:39:53,579 - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-08-08 14:39:53,579 - MainThread - adsk.dls.streamer - INFO :: # #
2017-08-08 14:39:53,579 - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000013E2C669E48> #
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\dgaynor\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\dgaynor\AppData\Local\Autodesk\webdeploy\production\df2c2875432b4bd0d6eb31cb9221197ebfddc515\resources\buildinfo.json
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20170524053800
2017-08-08 14:39:53,580 - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-08-08 14:39:53,581 - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\dgaynor\AppData\Local\Autodesk\webdeploy\production\df2c2875432b4bd0d6eb31cb9221197ebfddc515\resources
2017-08-08 14:39:53,581 - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
Me too - 404 error
Im trying to sell your software to my company and we cant test it is there someone who can help with this?
I'm having the same exact problem, I was really looking forward to the sheet metal update and then it fails to update. I tried turning off anti-virus and firewall but it still would not update. Hopefully this can get fixed soon, I really wanted to try out the new features.
I got my update to download by clearing the user cache and completely shutting down my computer, then turning it back on. Hopefully this helps someone else, I know it probably won't do much for those trying to install the trial, but it might be worth a shot.
RajkumarIlanchelian
We apologize for the download issues that you are facing. We have addressed this issue from our end. The download should work for you without having to clear cache or go about any other workarounds.
We apologize once again and hope you give our trial another chance.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
