Fusion Support
Still stuck in offline mode.
20 REPLIES 20
Message 1 of 21
hjartland
2326 Views, 20 Replies
I have tried everything in this link ...
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
The dashboard all reads green.
This has been going on for a couple weeks now. What else do I need to do?
Thank you.
20 REPLIES 20
Message 2 of 21
innovatenate
in reply to: hjartland
Can you upload a copy of the diagnostic log files?
The logs may contain some further information we can use to diagnose the issue. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 3 of 21
hjartland
in reply to: innovatenate
Where do I find this log file?
Message 4 of 21
innovatenate
The command is located in the help drop down menu. See the image in my last post for clarification.
Nathan Chandler
Message 5 of 21
hjartland
Where do I upload it? Do you want a text version in this field?
Message 6 of 21
innovatenate
There's a pace to add an attachment to your replies, below the text window. See this screenshot for a hint.
Can you upload the zip file?
Nathan Chandler
Message 7 of 21
hjartland
Ah. There it is. I was going between my PC and small phone screen.
Here you go.
Thank you.
Message 8 of 21
hjartland
It now reads as being Online!
IDK what changed, but thank you for your help! 🙂
Message 9 of 21
hjartland
Correction. It is once again stuck in offline mode.
It went into online mode for a short while. This occurred when the latest update installed.
Hope that helps narrow down the issue. Fusion 360 is a good program. Learning how to use it is made much better by the instructables class on 3D printing!
Thank you.
Message 10 of 21
innovatenate
Sorry to hear about the ongoing struggles!
In the log files, I'm seeing that Fusion believes there are network connectivity issues:
20170530T004053 I OnlineStatus onlineSwitchFailed: Unknown error.
20170530T004053 I OnlineStatus OfflineUI connectivity
Unfortunately, this batch of log files didn't highlight any specific reasons why. We've made some changes in the logging in the May 30th update that may help elucidate further. Could you try again and upload one more version of the diagnostic log files?
If you have any questions, please let me know.
Nathan Chandler
Message 11 of 21
hjartland
Here you go.
Message 12 of 21
innovatenate
Thanks for the log files. I'm seeing this warning:
20170531T145829 W FLAGS: failed to open flags file for write ***/Local/Autodesk/Autodesk Fusion 360/***/flags.json
This is an error while trying to save current feature flag state to disk so it can be used in offline mode. A couple of things which could cause this error are :
  • A lingering background process of Fusion running (check Task Manager for other copies of fusion360.exe)
  • Unexpected file permissions in the %localappdata% folder
Restarting the computer would take care of both of these possible root causes. Otherwise you may try:
Try killing rogue background processes related to Fusion 360:
1. Opening Task Manager (CTRL + SHIFT + ESC)
2. In the Details or Processes tab, find any process named Fusion360.exe and/or adcefewebbrowser.exe and select it
3. Manually end the Task using the End Taks command
Or try renaming the %localappdata% folder:
1. Open Windows Explorer
2. Browse to C:\Users\***\Local\AppData\Autodesk\
3. Try renaming the "Autodesk Fusion 360" Folder to "Autodesk Fusion 360 Backup"
4. Restart Fusion 360
I hope this helps. Let me know if you have any questions.
Nathan Chandler
Message 13 of 21
hjartland
Tried all of these steps. They all failed to fix it. Stubborn issue to be sure.
" ...  20170531T145829 W FLAGS: failed to open flags file for write ***/Local/Autodesk/Autodesk Fusion 360/***/flags.json
Failed:
Failed:
Failed:
renaming
4. Restart Fusion 360 ... "
Message 14 of 21
innovatenate
Which version of anti-virus software do you use? You might try adding an exception to the anti-virus software settings to see if there is any change.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Con...
Did you try running in Safemode with networking to see if there is any change in behavior?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Dia...
If safemode helps, there could be another process running on the computer that is impacting the file permissions.
I look forward to your update! Please let me know if you have any questions.
Nathan Chandler
Message 15 of 21
hjartland
Norton 360.
Yes I tried safemode w/net.
Just disabled Norton's Auto Protect and Firewall. Still offline.
Will try the exception next.
Thank you.
Message 16 of 21
hjartland
No luck finding how to white list / exclusion list a program through Norton.
Message 17 of 21
hjartland
I guess it is not Norton 360. It is the latest version of Norton out there. Norton Security Deluxe.
Message 18 of 21
innovatenate
I modified a post from this forum discussion below that may help.
https://community.norton.com/en/forums/how-add-folder-exceptions
There are a couple of different exclusion types: firewall, AC scans, and SONAR/Auto-protect. I'm going to assume it's SONAR.
To add a folder to SONAR exclusions:
  1. Open up the N360 interface.
  2. Select the "Settings" tab.
  3. Select "Antivirus" from the Detailed Settings field.
  4. Under the "Scans and Risks" tab, scroll down to the bottom
  5. Locate the "Exclusions / Low Risks" section
  6. Next to "Items to Exclude from Auto-Protect, SONAR...etc" click on "Configure [+]"
  7. A window should pop up labeled "Real Time Exclusions"
  8. Click "Add"  and browse to and try adding the below directories:
  • C:\Users\***\AppData\Local\Autodesk\webdeploy\
  • C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360
  • C:\Users\***\AppData\Roaming\Autodesk\Autodesk Fusion 360
 Note: Be sure to check the box for "Include subfolders"
9. Click "OK"
10. Click "Apply"
Then retest Fusion 360.
Does that help? I look forward to your reply.
Nathan Chandler
Message 19 of 21
hjartland
Tried much of the above. No luck.
But when visiting the site for Planet Side 2. Norton complained about a SONAR.xxxxxx file and recommended a complete removal.
After installing the game. Then rebooting. I opened Fusion 360 and it is in Online mode! 😄 So far it is stable.
Thank you,
Ben
Message 20 of 21
hjartland
Correction. After a number of days w/o using Fusion. I loaded it only to find a message about working in offline mode too long. Then another about my internet connection not working. It automatically closed.
After a minute I reloaded it. Only to find it in offline mode and complaining about it. Then I tried to toggle the online/offline switch. It failed, but I was allowed to work in offline mode.
Would it help for you try a remote desktop session? Or more screen shots of my processes?
Thank you,
Benjamin
