Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Break Link crash
4 REPLIES 4
etfrench
445 Views, 4 Replies
Break Link crash
Breaking the link for "HVR_Upper_CutterMount v2" is crashing Fusion 360.  Error Report 301639007.  Repro's consistently.
ETFrench
4 REPLIES 4
dsouzasujay
in reply to: etfrench
Sorry to see that you're facing this problem, I have created an internal bug to track this crash(FUS-79122)
Thank you for reporting the crash @etfrench
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
etfrench
in reply to: dsouzasujay
After manually replacing the offending components, I'm not able to export this as an .f3d file.  Is it related to this issue?
ETFrench
etfrench
It seems the exporting as .f3d issue is related to removal of a linked component.  Rolling the timeline back to before the Remove operation, then deleting the linked component, solved the problem.
ETFrench
dsouzasujay
@etfrench Its good to know you found a workaround to continue your work.
dev team are investigating the crash.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
