Fusion Support
Report issues, bugs, and or unexpected behaviors youโ€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Black/Blue lines again, advise
4 REPLIES 4
manolo.dev
334 Views, 4 Replies
Hi, I need some good soul to help me with this very basic problem I face in designing in most of my projects.
I understood I have to start to create a sketch on the origin of the page so the lines go black.
In this case, I have the bigger rectangle fixed at the origin, but how about the other sketches how can I make them black? I don't want to connect all together they will be printed apart.
I use to make sketches and move vertically so I can make extrusions where I need, Is that the correct way to do it?
in this case, I can not extrude the rectangle on the RIGHT side why is that?
If I try to edit I can not edit on the vertical side as well, I understand that is because the original sketch was made in another plane, how do you professionals do that? Thanks for any inputs ๐Ÿ™‚
Labels (1)
4 REPLIES 4
g-andresen
in reply to: manolo.dev
You did everything in a 3 D sketch.
You should preferably sketch on the surface that serves as the base for the extrusion.
Screencast
gรผnther
manolo.dev
in reply to: g-andresen
Hi Guenther, thanks for the advice, I thought would be clean project if you make only one Sketch. In this case if I have to change some parameters in the first sketch I can not see the second Sketch because is down to the timeline, Am I wrong?
Cheers.
g-andresen
If the 2nd sketch has a reference to the first one there are no problems.
This reference is made either by placing the second sketch on a body surface or directly to the first sketch via projection, as I did in the screencast.
If you then make changes in the first sketch, they will be taken over into the second sketch.
gรผnther
manolo.dev
I will try to find something about the references you are suggesting I don't know how to do that, neither how this works.
