Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
ATTN: Unable to Close Tab or Fusion 360 because Don't Save is not function
1 REPLY 1
James.Youmatz
908 Views, 1 Reply
Hi all,
It was recently discovered that you may be unable to close a document, tab, or Fusion 360 by selecting the Don't Save option. In this scenario you are forced to save. We are diligently working on fixing this issue and I will update this thread when it is fixed.
In the meantime, there are two workarounds:
  1. Save the document and then delete it (I do not recommend this)
  2. In your preferences, disable Auto Version on Close and restart Fusion 360
Once this option is disabled, the ability to use Don't Save will function correctly.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
1 REPLY 1
in reply to: James.Youmatz
I have same problem only after subscribing and setting up team hub.
Technology Administrators
