Fusion Support
Model does not align correctly when using "look at" command
4 REPLIES 4
ftporta
328 Views, 4 Replies
Hi All,
Has anyone seen what is happening in the attached screencast?   After extruding a cylinder, highlighting one of the faces at the end, and using the "look at" command, the model does not seem to align properly even though the view cube in the upper right hand corner is correct.  I've only noticed this after the last update.  Maybe I have something set incorrectly?
Thanks for any insight.
4 REPLIES 4
jhackney1972
in reply to: ftporta
Your screencast did not make it to your post.  Please post it again.  I tried what you described and Look At did a perfect alignment to the View Cube.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
ftporta
in reply to: jhackney1972
Change camera setting to "Orthographic" or "Perspective with Ortho Faces"
ftporta
Yes, that was it.  Thanks Manfred.
Technology Administrators
