why cant I select this plane?
ckVCFWD
Message 1 of 13
ckVCFWD
working in sheet metal,  I want to sketch on the thin surface like I did on the rest of this piece but for some reason, the softest part of this curving sheet metal cant be drawn on? video attached. you can see I can select any other surface as a plane to draw on except the one I want?
Replies (12)
Message 2 of 13
davebYYPCU
If you can’t select it, it is not a Plane.  Most likely it’s twisted.
Might help….
Message 3 of 13
ckVCFWD
its not, or there is no reason for it to be. it was a simple curved line, then flanged to extrude it, every other face that is parallel to the face I cant select is from the same extrusion operation, and they all can be drawn on, selected, and cut/extruded.
Message 4 of 13
davebYYPCU
Then it is twisted because you cut a curved flange with the extrude.
Might help...
Message 5 of 13
ckVCFWD
I did?  I dont see how. this is it right here. I dont see any twist.
Message 6 of 13
davebYYPCU
Optical illusion.  If you cannot sketch on the first extruded curved face, then it is unusual.
Might help...
Message 7 of 13
ckVCFWD
ok, so its a bug? or im being optically alluded?
Message 8 of 13
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
Message 9 of 13
ckVCFWD
here it is, very curious what im doing wrong
Message 10 of 13
HughesTooling
Seems to be a problem with using splines for a sheet metal flange. If you replace the spline with an arc it work as expected. @Phil.E  who would be best to tag in about problems with sheet metal
Mark Hughes
Owner, Hughes Tooling
Message 11 of 13
Phil.E
Thanks @HughesTooling . For sheet metal, I'm happy to look at issues, or you can tag @samuel.templeUCPAE for sheet metal specific issues. Either way, it'll get to the right people.
This does look like a case where splines are creating issues for that edge. Use arc or put a construction plane on that face (use 3 points or other method). Sorry for the inconvenience in the mean time.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 12 of 13
samuel.templeUCPAE
Thank you for reporting this. I will be speaking to my development team about this and hopefully get an explanation as to why this may be the case.
Samuel Temple
Senior Software QA Engineer
([email protected])
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
Message 13 of 13
samuel.templeUCPAE
A ticket has been created to investigate this issue further.
I believe this is an issue with sheet metal and splines. I left the spline rather than swapping it with an arc, then i used thin extrude, and i was able to use the top edge as a sketch plane.
FUS-159161
Samuel Temple
([email protected])
