Issue with importing DXF file
kishan_patel3
kishan_patel3
Community Visitor
Community Visitor
I am trying to open the dxf file in Fusion 360 and only seeing two circles but the file opens perfectly in the Autodesk Viewer.
Attaching the file here for reference.
HughesTooling
You have solid hatches in the DXF, Fusion's sketches do not support hatches so they a skipped by the importer.
You could try opening in QCad then explode the hatches then re-save as DXF. See attached file.
In QCad window select then explode.
Mark Hughes
Owner, Hughes Tooling
