Three Point Circle does not intersect the points selected to create it.
drew
Message 1 of 26
drew
I'm experiencing an odd behaviour of the three-point circle in a sketch.
Three points are chosen (at maximum zoom), yet the circle that results does not intersect the three points chosen, it is created just 'inside' the points.
Please explain if this is intended behaviour.
If not an intended behaviour, please fix it.
More detail for understanding is in the screencast.
Replies (25)
Message 21 of 26
bndrcr82a08e349g
I did the same, but on the dimension the circle line does not touch the arrowhead
Message 22 of 26
bndrcr82a08e349g
I did the same, but in the dimension, the circle line does not match the arrowhead
Message 23 of 26
TrippyLighting
That is a viewport display (tesselation) issue. Your sketch geometry will be just fine.
Message 24 of 26
bndrcr82a08e349g
I'm a little disappointed, in this thread the error was reported already in 2018, and now after 5 years it still hasn't been resolved... it's not a good thing.
Message 25 of 26
TrippyLighting
There is no bug or error here!
Tesselation is a necessary evil in any CAD system I have come across in 30 years of working with CAD professionally.
Message 26 of 26
TheCADWhisperer
@bndrcr82a08e349g
Can you File>Export your *.f3d file that illustrates this issue to your local drive and then Attach it here to a Reply?
