Event simulation issues
Dear autodesk engineers,
Is is normal that event simulation always breaks component.
I tried event simulation for almost 2 weeks now and my component always broke.
I was wondering and I tried to follow the sample given by your team and follow instruction in this clip (http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A22E2BC5-D0DF-46ED-B75E-D9CE8D40752E)
The result is the same. Component break.
Are you sure that there not a problem with your soft.
Thank you in advance for answering.
pawel.potyrala
Hello @Anonymous,
thanks for posting! Your results of the sample simulation from our Fusion 360 Learning site indeed do not correspond with the expected results:
Which material have you applied to the components? Can you share the link to the sample?
Thank you in advance!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
Dear @pawel.potyrala,
For the sample provided by your team, I used the same material.
For my own model, I used the same one, and other like ABS Plastic (for the upper body), Copper and Acetal resin for the PCB (fixed body).
Best regards.
I think the problem is that, there is no deformation. In case of contact (colision) the result is always the same. Non fixed body break themselves.
In case I am right, is it possible to use another simulation to reproduce the effect of snapfit like your demo?
Best regards.
pawel.potyrala
Hi @Anonymous,
I believe you had "Allow element deletion" activated in your simulation settings. Here's the comparison: https://a360.co/2B04zWK. The example in our learning site does not simulate part breakage - therefore the option is deactivated.
Let me know if that helps.
Best regards,
Paweł Potyrała
@pawel.potyrala,
Thank you so much for your help.
Your solution is working. Now, I must modify a little bit the model to have the best result.
Best regards.
