SVG Crash
SVG Crash
frandy_sanchezRY8QR
Message 1 of 12
SVG Crash
frandy_sanchezRY8QR
Since my Fusion 360 was automatically updated, I've encountered an issue where I can't import SVG files anymore. Simpler SVG files import fine, but I've been working on a specific project that was imported without any problems until recently. Now, whenever I try to import the SVG, the program gets stuck in a loop and eventually crashes. I tested importing the same SVG file on my laptop, which is running an older version of Fusion 360, and it imported successfully. Is this a known issue with the latest version of Fusion?
Replies (11)
Message 2 of 12
HughesTooling
Can you share an SVG you have trouble importing please?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 12
danielgriffiths
Observer
Observer
I'm also having simular issues, although no previous version to compare to!
I find, if I leave Autodesk Fusion (not responding) for long enough. 50% of the time they will eventually work.
But any large or complex .svg file that is imported  is causing the same issue
Message 4 of 12
danielgriffiths
Observer
Observer
Message 5 of 12
robertef3
Similar here. They will import for me but with an error that it can't "solve" something and then regions that used to be selectable spill into other regions. Worked before the update and now doesn't work.
Also reported as a bug here. I didn't see this one until after I posted and I searched so apologies to the bug handlers.
Message 6 of 12
frandy_sanchezRY8QR
The SVG file containing the car consistently triggers a crash error, and the SVG for the red legs isn't functioning either. It's frustrating because I've been using the same Redlegs SVG file for the past three days without any issues prior to the update.
Message 7 of 12
Phil.E
Thanks for posting, and sorry for the inconvenience while this gets sorted.
Message 3 on this post shows that the developers are looking at the issue.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 12
danielgriffiths
Observer
Observer
Okk, I have a great work around that allows you to very quickly setup the .svg in fusion without any issues.
If you have access to fusion in a browser, you can go there upload your .svg in seconds (I assume how fusion desktop used to deal with this)
If you save this to your fusion account, you can then close the browser version, open desktop and retrieve you're beautifully uploaded vector file. 🙂
Message 9 of 12
frandy_sanchezRY8QR
Thank!!
Message 10 of 12
sameer_babarNJS6C
Hi All,
Thanks for reporting this issue to us.
Now we have deployed a fix for this issue with our latest update 2.0.19440, please update Fusion to latest version to avoid this issue.
Sameer Babar.
Autodesk Fusion Team.
Message 11 of 12
frandy_sanchezRY8QR
Thanks for the quick fix!!!
Message 12 of 12
distilledoasis
Community Visitor
Community Visitor
