Fusion 360 Crashing On Asus ROG Flow
ThePieMonster
Message 1 of 1
ThePieMonster
Hello.
I wanted to try and debug Fusion 360 on the ASUS Flow X13. It has a switchable GPU which might be a factor in the issues I am having. On a a different computer (workstation) Fusion runs fine 95% of the time, but on the X13, it crashes all the time.
The application will crash sometimes on open, close, or when sitting idle and sometimes when trying to make a large change like hiding the visibility of a complex object.
I don't have any logs in the following location.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-manually-co...
C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\(Alphanumeric Folder)\logs  (Look for all *.log files.)
C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\logs  (Look for all *.log files. Logs here when login is unsuccessful.)
Replies (0)
