Surfaces ?
Surfaces ?
jsLZWXV
Message 1 of 10
Surfaces ?
jsLZWXV
Hi , I made a kind of bowl, inside the wall there have to be placed a space for kind of seal. I made the seal, move into the wall and after I cut it out, I can't select the inner profile (which has to be modified), there is always a surface on top? I tried to delete , but I can't. Clearly visible in the section analysis.
Thanks in advance. Jens
Replies (9)
Message 2 of 10
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 3 of 10
jsLZWXV
Sure Günther ....
Message 4 of 10
jsLZWXV
I tried to upload this picture as well, it failed. This shows how one surface is blocking me to modify parts of the rings.
Message 5 of 10
g-andresen
the ring wasn´t in a correct position.
I used MOVE > point to point
Screencast
günther
Message 6 of 10
jsLZWXV
Hi Günther, Thank you very much, I will try. Did you check if you can now select only the inner ring as attached to modify?
Message 7 of 10
jsLZWXV
Yes Günther its working, thanks again and nice weekend!!
Message 8 of 10
g-andresen
thank you, same for you.
I recommend: Put such profiles in place from the beginning.
Screencast
günther
Message 9 of 10
jsLZWXV
Good advise !!! Thanks Günther .
Message 10 of 10
g-andresen
Please mark contributions that made a solution by checking them as "Accepted Solution".
This will make it easier for future readers.
günther
