Students opening Fusion Web Browser Help
rmalerbi
Message 1 of 36
rmalerbi
I have three classes of students using Fusion 360, roughly 30 in total. Some of my students have been able to open the Fusion web browser but most of them have issues loading the program. Some are getting kicked off with a Time Out error, some will get the browser to load to 100% but it will never open. Students with Macs, I have them try opening the web browser with Chrome and Safari. The time out issues seem to happen throughout the class. All of my students have educational access to Fusion, only a few have an assigned copy from me. I have gone to the IT department for the school and they determined that it tis not an internet access issue. It has been a significant set back in the class. I have been using the program with my classes for a few years now and this is the first time I have had this many issues. Is anyone else have the same issues? Have you figured out a solution? Anything helps at this point.
Replies (35)
Message 21 of 36
RajkumarIlanchelian
We are certainly not ignoring the thread nor the problem. This is impacting select customers and our work with AWS to address is high priority. We are hoping that later this evening we will have a new version of Fusion along with this issue addressed. Will certainly post back here with any updates.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 22 of 36
RajkumarIlanchelian
Reporting back here with an update that this issue should now be addressed.
We do apologize for the experience over the last few days.
please do let us know if the issue has been resolved in your workflows.
Autodesk Fusion
Join Fusion Insider
Message 23 of 36
KhendricksonDJFWU
Still getting the issue as the day progresses unfortunately. We gave it a shot Friday and had the same effect. Morning had luck getting in (like normal) and as the day progressed less and less were able to access. We are now having reports of the issue again at sites in the AM.
Message 24 of 36
booyah75
We had great results on Friday, students were able to get in and have plenty of time to work. Many said the loading time was even faster than it was last year. This was between 1:30-3:00 central time. We'll be using it again today through November so hopefully it stays fast.
Message 25 of 36
RajkumarIlanchelian
@KhendricksonDJFWU Canyon please try to clear the browser cache and see if that helps?
Autodesk Fusion
Join Fusion Insider
Message 26 of 36
rmalerbi
We had some luck yesterday during class, today seems to be back to the same errors.
Message 27 of 36
rmalerbi
I had my students clear their browsing cache but still not much success. They are getting back into Fusion slowly and when they are in Fusion, they do not have access to their data panel. So they have no access to their drawings.
Message 28 of 36
booyah75
So we have been having issues getting past the Launch screen. 8-15 students out of 30 were spamming the LAUNCH FUSION button for 30 minutes and never got to the loading screen. If we get to the loading screen it has been good the last few days.
Message 29 of 36
rmalerbi
My students seem to be having the same issue again. Lots of them getting kicked out 20 minutes into use and 504 Gateway errors.
Message 30 of 36
RajkumarIlanchelian
@rmalerbi Apologies for the late reply. There was a problem we have identified and addressed. This should not be an issue moving forward. Please confirm if you are still seeing the problem.
Autodesk Fusion
Join Fusion Insider
Message 31 of 36
agau9FUTN
Good Afternoon,
While the situation seems to be improving my classrooms will still experience the same issue with several students (~25-30%) experiencing 504/502 Gateway Errors or Internal Server Errors.  The errors seem to be hardware and browser agnostic (Laptops, Chromebooks, and desktops are affected and as well as different browsers).
Message 32 of 36
ajbeavan
Observer
Observer
@RajkumarIlanchelian
Students are getting Gateway Timeout 504 trying to access through the Web front end
Message 33 of 36
RajkumarIlanchelian
@ajbeavan Checking with our engineering team.
Autodesk Fusion
Join Fusion Insider
Message 34 of 36
CGBenner
@ajbeavan
Has this been resolved yet?
Chris Benner
Message 35 of 36
ajbeavan
Observer
Observer
No, sorry this has not been resolved yet. Initially I thought it was the
hardware within our computer suite, but that has all since been upgraded
and we are still getting 'Gateway Timeout Errors' at your server end. This
is very frustrating since I have invested a lot of time with Fusion and the
students need to complete the CAD element in order to pass the course.
Adam
Message 36 of 36
terry.reiter
Since we use Chromebooks, I moved my class over to Onshape. So much easier
and convenient. Only drawback is no CAM but I can download from Onshape
with a STEP file and finish the CAM portion on my Fusion desktop. Also,
Onshape is very similar to Solid Works.
