Spurious error message at startup?
crueby1
Message 1 of 53
crueby1
For the last couple weeks I've been getting a notification up in the Job Status icon when I start Fusion, saying that 'We are untangling some wires' and that response may be slow, check health status board for details. If I go to the status web page, it shows nothing but all fine for Fusion. So, why the notification? Finally realized that as soon as I do some action like saving a project that does an upload to the Fusion server, that notification goes away. Something stuck??
Replies (52)
Message 21 of 53
crueby1
Correct! It can take a minute or so for the untangling message to appear, the verification one is as it starts up (along with the splash screen)
Message 22 of 53
crueby1
Been a few weeks now - any progress on fixing this, or at least figureing out the cause??
Message 23 of 53
RajkumarIlanchelian
@crueby1 Really don't have much of a solution since this is not a common issue that is reoccurring. So it is a bit more isolated that we need to figure out. I am still a bit surprised that you are still seeing the untangling wire message linger around.
lets keep working on this:
1. Close down Fusion and make sure that task manager does not show any running Fusion exe
2. Go to C:/Users/USER ID/AppData/local/Autodesk/Autodesk Fusion 360/Can you capture an image of the folders you see in here?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 24 of 53
crueby1
Here is what is in that folder:
Message 25 of 53
RajkumarIlanchelian
@crueby1 Can you please delete the folder "VNQ....." and start Fusion again. It should ask you to login again and let me know if the untangling wires goes away.
Autodesk Fusion
Join Fusion Insider
Message 26 of 53
crueby1
Did that, and it did not ask me to log in again, and the untangling wires message still came up after a minute. I noticed that the VNQ folder got recreated as Fusion came up.
Message 27 of 53
crueby1
Did you want me to kill off the Autodesk desktop licensing service, etc too? This issue has carried on over system reboots.
Message 28 of 53
RajkumarIlanchelian
@crueby1 I certainly thought the above would address the untangling wires. Ok. So let's do this with a clean shot.
1. Close Fusion and any other Autodesk products running in the background.
2. Go to add/remove programs
3. Autodesk Fusion - change/modify
4. This launches the service utility
5. First run the reset command
6. Close Fusion service utility
7. launch Fusion
8. This should ask you to login
9. Notice if you see the untangle wires and any cert warning
10. If you do see it , do nothing and go to
11. help - support and diagnostics - Fusion service utility - Gather system info and one again please attach the Fusiondiagnostics logs, zip please.
Autodesk Fusion
Join Fusion Insider
Message 29 of 53
crueby1
Okay, that time it did have me log in again. I did see the server warning this time, though I have not seen the untangling wires message after a few minutes. I gathered the log, that is attached.
One other thing that I've seen the last couple days, unrelated to this issue, is the message to 'Upgrade Project Type' one over in the left window. That one is quite confusing, the 'learn More' link doesn't explain it much either. I am a single user, in a team with just me as the admin no other users, does that message apply to me? Do I want to make that change? It doesnt really say what/why...
Message 30 of 53
RajkumarIlanchelian
@crueby1 Thank you for the logs.
1. Lets wait a few more minutes to see if the untangle comes back
2. New logs hopefully gives insights into the cert warning that could be the root cause of everything
3. Is the below image what you are talking about ?
Autodesk Fusion
Join Fusion Insider
Message 31 of 53
crueby1
Yes, thats the message I was asking about in the last post.
So far no untangling popup, maybe you got it that time. The server warning was still there.
Message 32 of 53
crueby1
Okay, took 15 minutes or so, but the untangling wires message DID come up again!
Message 33 of 53
crueby1
Grabbed a new set of log files after the untangling message came up, its attached.
Message 34 of 53
RajkumarIlanchelian
@crueby1 Thank you for both the logs. Took a look at the first one and see that a SSL connection to this is failing often - https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.json
In your browser can you click on this and see what results you get? Also click on it in certain intervals and see if it fails to connect at any point. Currently the first logs shows many errors connecting to this.
I will check on the second logs now.
Autodesk Fusion
Join Fusion Insider
Message 35 of 53
RajkumarIlanchelian
The second log is also filled with these:
20240306T170602 E 13088 GET 35 https://js.prd.fusionapi.autodesk.com/hds/fusion360.json dt=0.16 schannel: failed to receive handshake, SSL/TLS connection failed
20240306T170602 I 18336 GET 0 https://js.prd.fusionapi.autodesk.com/hds/fusion360.json - workflow:HTTPClient attempt:0 requestId:f360_HTTPClient__1-65e8e8ca-aa2f340210f5404d99cf0d3d dt=0.17
20240306T170602 E 18336 ServicesHealthStatus: Problem parsing HDS response: Response body is not a valid json
this clearly shows that we are not able to connect to the health dashboard and hence we throw up the degraded untangling wires. There seems to be intermittent connect issues to https://js.prd.fusionapi.autodesk.com/hds/fusion360.json
Will wait for your reply on what happens when you access this from your browser.
Autodesk Fusion
Join Fusion Insider
Message 36 of 53
crueby1
If I click on those from the browser, it seems to go through every time, have tried it over and over, quick, slow, etc.
Could it have something to do with whatever is happening in Fusion at the time, a higher priority action in my modeling work, other commands, etc, making it time out even if the network responded okay? I dont see anything in the firewall logs, system logs, anything like that.
Here are the results from the first one:
product
id"fusion360-runtime-config"
metadata
cpxmovecopy"no"
AnyCAD"yes"
UserVoiceEnabled"no"
BranchingEnabled"yes"
tHODisabled"yes"
ECM"yes"
SupportSolidEdgePartFile"yes"
SupportStepFile"yes"
OnDemandLMV"yes"
crossprojectreference"yes"
FusionSingleTier"yes"
fusion-asm-fpe"no"
symphonydm"no"
TeamHub_ShowCreate"no"
DisplayRetirementMessage"yes"
anycadassembly"yes"
DisableLegacyGLProfile"yes"
FusionGenerativeTrial"yes"
EnableEvergage"yes"
SupportPrtFile"yes"
GenerativeForStudents"no"
autodeskgenerativedesignlink"yes"
MfgExtGraceAccess"no"
PersonalUserCapacityLimit"yes"
use-trials-service-for-product"yes"
IDSDKEnabled
"yes"
and the second one:
id"fusion360"
name"Fusion 360"
previous_status"degraded_performance"
restore_delay
commercial60
free720
trial120
since_time"2024-03-05T19:29:56.054-08:00"
status"operational"
status_badge"Operational"
updated_at"2024-03-05T19:29:56.054-08:00"
Message 37 of 53
crueby1
Also tried those links with Fusion up and running, same responses then. After a while, when the untangling started showing, clicked on them again, still same responses.
Message 38 of 53
crueby1
Another tidbit, I had wondered if it was some action I was taking in Fusion at the time keeping it busy and making it time out, but jsut saw it display the notification even when nothing was going on for several minutes.
Message 39 of 53
RajkumarIlanchelian
@crueby1 Its possible that when these are sent by a browser your network is allowing it but when it comes from Fusion there could be some rule that may be blocking it.
Here is a document that talked about this in detail and some options to check to see what could be the issue - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Server-Verificatio...
We will keep working through this to identify what exactly is stopping this one.
Autodesk Fusion
Join Fusion Insider
Message 40 of 53
crueby1
Yes - I had seen that article back before I reported the problem, thats how I found out about the option to ignore the warning. The system time is in sync, OS is all up to date, there is no proxy server, the firewall is letting Fusion through, nothing in the logs for firewall or the OS when this happens, which there would be if it had blocked Fusion (firewall is set to log all blocks based on the rules). My PC is connected directly to the cable modem, no other routers or proxy or anything between. The server warning comes up every time Fusion starts, but the Untangling message comes and goes, if there was a rule blocking it, it would never go through.
