Sketch problem
Sketch problem
mtaylor7KHWS3
Message 1 of 13
Sketch problem
mtaylor7KHWS3
When I start a sketch, I select the face I want to sketch on and then that face zooms completely off my screen. The origin is placed in the center of the screen instead.  I have to reposition the view in order to complete my sketch. Why does this happen?
Accepted solutions (3)
Replies (12)
Message 2 of 13
davebYYPCU
Check your Preferences,
Auto Look at sketch on creation, zooms to fit all that is in the sketch,
a new sketch only has an origin, so it zooms onto the Origin.
Auto Project references to the sketch on Create has a similar effect, but you still have to see the Origin in the Fusion system.
Might help....
Message 3 of 13
mtaylor7KHWS3
Is that supposed to be checked or unchecked?
Message 4 of 13
davebYYPCU
What do you prefer?
Message 5 of 13
mtaylor7KHWS3
I would like to see the face I am going to be sketching on come into view on the canvas regardless of where the origin is.
Message 6 of 13
davebYYPCU
Then you would turn it off,
which means you do it yourself with, Look at (this face).
Might help......
Message 7 of 13
mtaylor7KHWS3
Where do I find that command?
Message 8 of 13
jhackney1972
If you have turned off "Auto look at sketch" in your preferences, when you start a new sketch you can find the Look At command on the Sketch Palette.
John Hackney, Retired
Message 9 of 13
Risa.Oram
Thank you! This worked for me. This was much more difficult to try to find an answer for than it should have been. Old documentation videos and ChatGPT still try to point you to the grid menu to adjust this.
Message 10 of 13
johnnysnowball
I have this same issue, however, if I uncheck Auto look at Sketch, it does not align me to the sketch at all, so I must have that checked. But either way, when i hit Look at Sketch it also zooms me away to the centre of the project. i am getting painful finger joint with constantly having to scroll-zoom out to locate my sketch face, and scroll-zoom back into that.
Message 11 of 13
TheCADWhisperer
@johnnysnowball
Message 12 of 13
johnnysnowball
This isn't unique to a particular model it's how it is and has always been on every project since I started some years ago. if i am zoomed in close enough to a surface so that i can work on it, and i select that surface to sketch on, it warps me to the central point of the project at that zoom level. i then have to scroll out to reorient myself, and scroll back in to the actual surface I selected. It baffles me why it doesn't actually focus on the area I selected. The view IS at the same angle as the surface I selected.
Message 13 of 13
TheCADWhisperer
@johnnysnowball wrote:
This isn't unique to a particular model…
Good to know.  In that case you should have plenty to chose from.
