Missing cut lines from a imported DXF file
vszym
vszym
I imported a picture from the internet into Inkscape to use for practice.  After downloading it into Inkscape I traced the bitmap and saved it as a DXF file.  I then imported it into Fusion 360 for personal use as a DXF file.  After finishing the setup and cut requirements I ran the simulation.  Only a few of the cut lines were picked up.  I have imported other DXF files and have the same issue.  I am very new to Fusion 360 so any advice would help.  I attached my file for review.  Also this is only for my practice.  I do not plan to cut it.  So hopefully I am not breaking any copyright laws.
HughesTooling
If you mouse over the error it tells you what's wrong.
You have quite a large lead in distance, try reducing it. You might even need to turn leads off to cut the letters.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Looking closer, you are going to need a lot smaller nozzle than the tool you've selected. If I edit the tool so the nozzle and Kerf width are 0.04" and turn off lead I can get it to cut most of the profiles profiles but could do with even smaller. Do you know your nozzle and kerf sizes?
Mark Hughes
vszym
Thank you I will take a look a closer look at my cutter specifications.
