Remove my account and files from your servers
marko
marko
How can I remove my account from your site and all files the F360 sent to your servers?
sutherland-
Hi @marko
To Delete your account do the following:
Note: After you delete your account, you will no longer have access to your files. Be sure to download your files before proceeding.
  1. Sign in to your account at profile.autodesk.com/security.
  2. Click Start Deletion under Delete account and data.
  3. Review the alternative actions to make sure you want to delete the account and not limit emails, turn off auto-renew, delete a user, or cancel a trial.
  4. If you’re sure you want to delete the account, click Continue With Deletion. You'll be asked to re-authenticate your sign-in information for security purposes.
  5. Select email, text, or call to receive a verification code. Text and call options are only available if you have previously set up two-step verification on your account.
  6. Click Continue With Deletion.
  7. Enter the verification code and click Continue With Deletion. A verification screen displays.
    Note: Once an account is deleted, you are unable to create a new account with the same email address for 45 days.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
