Text size bug in revision history table
I noticed a bug with the text size in the revision history table. It might have been introduced with the latest updates, that I got a few days ago, but I'm not sure, because it's been a while since I had to use the Drawing Workspace.
The Revision history seems to only take integer values for custom text sizes now. I usually use 2.5mm as text height and in all my old drawings it works fine, if I don't change anything. When adding a new revision to the table, the new table row will be automatically set to the default value auf 3.5mm text height (also a bit annoying sometimes, but this has always been the case, so it's beside the point). I usually fix this by resetting the text height for the whole table to 2.5mm, because it's the fastest way to do this, especially when I add more than one revision.
However, even though the properties window shows 2.5mm (see first screenshot) the text height is set to 2mm instead. When I click into the table cell to add a description the text height property also shows 2mm text height (see second screenshot). If I go back to the table properties, now it shows 2mm there, too. And if I change it to 2.5mm nothing happens. Same goes for 3.5mm, 4.5mm etc. It seems like decimals are just cut off of the user input and just uses 3mm, 4mm and so on.
This does also apply to completely new drawings and new revision history tables. If I change the text height, I can't use decimals anymore. Text fields, Annotations and the general text size settings for the whole drawing work fine, though. It also works fine when I change the text height in the small text properties window, when I'm in a specific table cell. It's only the revision history properties window, that has this bug.
