BUG. Boundary Fill on component copies fails!
HughesTooling
Consultant Consultant
HughesTooling
I was trying to help someone in manufacturing and needed to make copies of a set of soft jaws before they are modified. The best way to do this is with boundary fill because copy\paste is a timebomb waiting to wreck your design!
So selection looks fine using boundary fill on the 2 copies.
But after clicking OK you get this warning and only one body is copied. If you can use Copy Paste New to make the original copies it work fine, only fails with copied\patterned components.
Mark Hughes
Owner, Hughes Tooling
johnsonshiue
Hi Mark,
I believe this is a bug in Boundary Fill. The issue here is that the selected tools and the cells point to the same component. It seems that the transformation due to Move/Copy, was not taken during the Boundary Fill operation. I can reproduce the behavior. I will forward it to the project team for further review.
Many thanks!
Software Test Engineer
