Rectangular Pattern Bug
joegroom
Message 1 of 9
joegroom
When creating a rectangular pattern that includes the chamfer feature in the timeline, the Z axis is selected as one of the options no matter which axis is selected. It doesn't allow me to have a rectangular pattern in the X and Y directions, only X and Z or Y and Z.
After messing with the feature selections, if I remove the chamfer as a selection, it works correctly.
I have 2 extrudes in the Z axis and 1 chamfer I'm trying to replicate.
After trying a few times, I was able to get it to work once and saved it but picking the axis again was still causing the Z axis to be selected.
When the chamfer is selected, it gives extra faces even when it was correctly using the X and Y axis.
This is in version Fusion 2.0.19966 x86_64
Replies (8)
Message 2 of 9
TrippyLighting
Please share the design if your in a position to do so.
Message 3 of 9
joegroom
Here's the file. I've made changes and saved since this version but this is where I was at with the problems.
Message 4 of 9
TrippyLighting
Yep, I've seen this before.
No matter which axis one selects, Fusion does not offer a 2nd axis in the XY plane.
Thanks for reporting! @Phil.E can you check this out?
Message 5 of 9
joegroom
Thanks for quickly looking into this and replying!
Message 6 of 9
Phil.E
Pattern the faces, not the features.
I'll send this over to the pattern development team. Thanks!
Here are the steps for your design. Edit the pattern and do this:
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 9
joegroom
Thanks for the work around and sending this over to the dev team.
Message 8 of 9
Phil.E
No problem glad to help. I think you might find in time that patterning faces, when the faces are all discrete like this, is just another workflow. If I can select the faces like this, I don't even think about patterning features. Usually I only pattern stand alone features, like a hole operation. In any case, the feature pattern should be more reliable than what you discovered, the dev team will look into it.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
samuel.templeUCPAE
I am the QA for the Pattern feature. Thank you for bringing this issue to our attention.
I will be discussing this with my dev team
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
