Rectangular Pattern Bug
joegroom
Message 1 of 9
joegroom
When creating a rectangular pattern that includes the chamfer feature in the timeline, the Z axis is selected as one of the options no matter which axis is selected. It doesn't allow me to have a rectangular pattern in the X and Y directions, only X and Z or Y and Z.
After messing with the feature selections, if I remove the chamfer as a selection, it works correctly.
I have 2 extrudes in the Z axis and 1 chamfer I'm trying to replicate.
After trying a few times, I was able to get it to work once and saved it but picking the axis again was still causing the Z axis to be selected.
When the chamfer is selected, it gives extra faces even when it was correctly using the X and Y axis.
This is in version Fusion 2.0.19966 x86_64
Replies (8)
Message 2 of 9
TrippyLighting
Please share the design if your in a position to do so.
Message 3 of 9
joegroom
Here's the file. I've made changes and saved since this version but this is where I was at with the problems.
Message 4 of 9
TrippyLighting
Yep, I've seen this before.
No matter which axis one selects, Fusion does not offer a 2nd axis in the XY plane.
Thanks for reporting! @Phil.E can you check this out?
Message 5 of 9
joegroom
Thanks for quickly looking into this and replying!
Message 6 of 9
Phil.E
Pattern the faces, not the features.
I'll send this over to the pattern development team. Thanks!
Here are the steps for your design. Edit the pattern and do this:
Phil Eichmiller
Software Engineer
Quality Assurance
Message 7 of 9
joegroom
Thanks for the work around and sending this over to the dev team.
Message 8 of 9
Phil.E
No problem glad to help. I think you might find in time that patterning faces, when the faces are all discrete like this, is just another workflow. If I can select the faces like this, I don't even think about patterning features. Usually I only pattern stand alone features, like a hole operation. In any case, the feature pattern should be more reliable than what you discovered, the dev team will look into it.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 9 of 9
samuel.templeUCPAE
I am the QA for the Pattern feature. Thank you for bringing this issue to our attention.
I will be discussing this with my dev team
Samuel Temple
Senior Software QA Engineer
([email protected])
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
