Randomly multiplying every extrusion
Finn.uckelmann
Finn.uckelmann
As you can see in the picture, every extrusion I make is multiplied no matter what. How can I fix it?Screenshot 2023-07-12 154247.png
HughesTooling
You probably need to share your design as an f3d so we can take a look. Best guess would be you have 3 instances of a component. As all the components will be identical adding an extrusion to one adds it to the others.
Mark Hughes
Owner, Hughes Tooling
Finn.uckelmann
Makes sense because I am designing a gearbox with 3 gears.
HughesTooling
I'm not sure what's going on. Even though the main component is active, as soon as you create an extrude a different component becomes active. Looking at your design timeline I have to tell you it's a complete mess and I'm not suppressed Fusion's getting confused. Some pointers, fix all warnings and errors in the timeline. If you have a move in the timeline you're probably doing something wrong, if you have a capture position in the timeline you're probably doing something wrong, same goes for remove. I don't know if you'll be able to fix the problems now because you have so many. Look at Rule #1 and start again would be my advice and ask questions before getting too far.
Mark Hughes
g-andresen
I think the file is corrupted.
Only after opening the file a second time could I detect the error.
Compute all made the system freeze.
günther
