I have the geometry below (Segments/Sketches/Half) that I would like to change: replacing the parts stroke out red (edges at the top and the two arcs) by the green ones (co-linear lines at the top, lines replace arcs at the bottom)
I can easily do this in this sketch but this geometry is used in Segments/Sketches/Full as source of a circular pattern (to create the upper half) which output is then uses in a rectangular pattern to create the second digit and again to create the 3 2-digit groups. There are also offsets to the geometry from Segments/Sketches/Full in Case-4D/Sketches/Segments that are then extruded.
The output of all this might also be used with constraints and dimensions to position other stuff.
When changing the geometry in 'Half' by inserting the new lines and deleting the old stuff, things in 'Full' become invalid.
When projecting the missing lines from 'Half' into 'Full' and adjusting the objects to be used for the circular pattern, the depending rectangular pattern disappear suddenly. And so forth...
I could not find a way to do this edit without practically reconstruct most of the project, witch would be a lot of work and error-prone.
Any suggesting how to do it?
