Problem when embossing on to curve surface from an SVG profile
Rollmop
Message 1 of 13
Rollmop
Hello, I have noticed some strange behaviour when I try to emboss an SVG profile onto a curved surface.
If you look at the screen clip, the sides of the 'H' have some strange curves on the emboss feature, but the sketch has straight edges.
I have also embossed some plain text onto the same surface, and no problems are seen.
Replies (12)
Message 2 of 13
Rollmop
another one not working as it should
Message 3 of 13
jhackney1972
Please attach your model giving you the issues.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
Message 4 of 13
Warmingup1953
Can you share your Fusion file and the .svg?
Message 5 of 13
Rollmop
Here is the f3d file
The SVG sketch should be visible
Message 6 of 13
Rollmop
here are the SVG's
Message 7 of 13
Warmingup1953
I think it may be the geometry of the .svg isnt ideal.
Here is your H from the .svg
and here is one from a Project Salvadore Autotrace of a screen capture of the .svg opened in CorelDraw...Not great but better:
and drax:
Message 8 of 13
Rollmop
So you think it's the SVG?
Message 9 of 13
Rollmop
I have created another test flat, curve and semi sphere, and just embossed simple text 'Arial' and a slightly more complex font 'Wingfoot',  it seems to handle the simple text ok, but struggles with the wingfoot on a compound surface
So I guess it's a bug in Fusion. I am sure the calculations are massively complex, but need tweaking
Message 10 of 13
TheCADWhisperer
@Rollmop
Try Explode Text (you will have to resolve the Emboss after changing).
I also noticed that your original design could be significantly simplified.
Message 11 of 13
Rollmop
Tried that, does not seem to make any difference
Message 12 of 13
parable-sinkers6s
Community Visitor
Community Visitor
any luck? I'm having the same issue trying to deboss an SVG logo onto an egg shape.
Message 13 of 13
TheCADWhisperer
@parable-sinkers6s
It probably would have been best to start a new discussion thread.
