Cannot installed Fusion 360
nadimDVDDE
Observer Observer
Message 1 of 9
nadimDVDDE
Observer
Observer
Try to install it fresh as soon as It goes to 100% it fails.
They suggest me this URL (The error in on that page as well): "Problem installing Fusion" during Fusion installation
but I cannot even use the Fusion Utility Tool.
I tried to uninstall it plus I removed those directories:
AppData\Local\Autodesk\webdeploy
AppData\Local\Autodesk\ODIS
ProgramData\Autodesk\ODIS
try to install it again no luck. I'll attach the logs.
Replies (8)
Message 2 of 9
RajkumarIlanchelian
@nadimDVDDE
Can you please try this?
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
nadimDVDDE
Observer
Observer
Something that I forgot to add when is done failing, I can see that creates Autodesk Fusion [Insider]. But i cannot do anything, i cannot open it, i cannot modify it or uninstall it.
Message 4 of 9
nadimDVDDE
Observer
Observer
The user has other Autodesk apps installed.
I tried already by removing those directories:
Is it safe to do the ones that you mention? (Web Services, Identity services, Autodesk Fusion 360) If i can find them.
Message 5 of 9
RajkumarIlanchelian
@nadimDVDDE Yes, it is safe to remove those folders.
Are you installing the Insider version of Fusion?
Autodesk Fusion
Join Fusion Insider
Message 6 of 9
nadimDVDDE
Observer
Observer
I'll check that but on the website there's one Fusion product. Thanks for the suggestion.
Message 7 of 9
RajkumarIlanchelian
@nadimDVDDE I was asking that because you mentioned this - I can see that creates Autodesk Fusion [Insider]
Have you signed up for Insider and is the insider build that one that cannot be installed?
Autodesk Fusion
Join Fusion Insider
Message 8 of 9
nadimDVDDE
Observer
Observer
I'll check, you see a friend of mine has the issue, and I'm trying to assist him. There's a good chance that he messes it up from his side. I wasn't even aware of an Insider version.
Message 9 of 9
lauri_barnhart
Hi @nadimDVDDE,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
