network diagnostic problem https://a360-statusdashboard.s3.amazonaws.com/autodesk_maintenance.json
vyviora
Message 1 of 31
vyviora
Community Visitor
Community Visitor
Hi
I need some help.... i have a network problem... and i tried and read a lot of options... but i dont know how can i fix it...
I have a red dot next to this:
And i dont know why...
Replies (30)
Message 21 of 31
Mat4Shell
Observer
Observer
Hi Rajkumar,
Thanks for your reply, I just tested with another account and it works perfectly... The problem comes from my account...
Message 22 of 31
BWENGUK
Just found this topic. I regularly get this issue in the morning if I have hibernated or slept my machine overnight. I am forced to restart Fusion, which can be a PITA if I am in the middle of a project with lots of things open. I made a thread here a while ago about this:
https://forums.autodesk.com/t5/fusion-support-forum/fusion-regularly-going-into-offline-mode/td-p/13...
Message 23 of 31
taylor_kACA53
It happened again today. The two diagnostics logs are attached.
Message 24 of 31
devilcrashh
I'm experiencing the same issue. Impossibile to log in into Fusion.
Message 25 of 31
RajkumarIlanchelian
@devilcrashh Can you please attach the logs?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 26 of 31
alexNAFT9
Observer
Observer
I am having the same problem. It started today after the latest fusion update.
Message 27 of 31
anthony.blakeV9F99
Community Visitor
Community Visitor
I have also been having this same problem for about a week or so. On my home wifi network and tethering to my mobile hotspot Fusion 360 works fine and goes online.
On my office wifi, Fusion takes forever to load and when it finally gets the open, it's in offline mode. If you click anywhere on the open screen it results in the spinning wheel.
If i switch to mobile hotspot in the office location it works as normal.
I would love a solution as it's doing my head in.
Message 28 of 31
alexNAFT9
Observer
Observer
Posting this for the good of the group....  I received an email from Autodesk CER (Customer relations) this morning that recommended that I update my 3D Connexion space mouse drivers to resolve this... Magically that seems to have worked! Hope that works for some of you out there.
Message 29 of 31
devilcrashh
It's crashing also the utility to collect Logs.
Message 30 of 31
devilcrashh
When I click on ACCEDI (LogIn), appear this window, fully transparent, where I can navigate on my C:\ drive:
and Fusion remain blocked in this way till I kill the process from the task manager.
Message 31 of 31
devilcrashh
SO???? ANY NEWS??? I'm still in stuck.
