Multi part hole making
BillGEGHV
BillGEGHV
Hi All,
This is a pretty newbie question even though Ive been using Fusion for quite some time, I still have not figured out if there is a better method of creating holes in multiple objects at the same time.
As you see in my screenshot I want to create a hole operation that goes through both objects in a single command, in the front (black) part I need a clearance hole with a countersink.  Then on the gray part, I simply want a tap hole size.  Simple, basic, standard stuff we do all day long in Fusion.  BUT I want to know if you can do this in a single command. Place a simple clearance hole, counter sink hole, OR counterboar hole, on part # 1,  then a tap hole in the other part BUT all in one command.  Can you do this??  Or do you need to work with one body at at time?
jhackney1972
You cannot do what you desire in ONE command.  You can used the same hole center point to create what you are looking for in multiple commands.
John Hackney, Retired
BillGEGHV
Thanks for confirmation.  This should be added to the wishlist, it's a PIA to do in 2 commands IMHO, but I see why they do it this way since you're adding features to 2 components.  But they could figure out a way around that, this is SO basic and a thing we to ALL the time.  IS there an active wishlist?
