Meshing stops progressing and program freezes completely when I try to cancel
julianne_jager
julianne_jager
Meshing stops progressing at 82% every time (80% in another assembly). No error comes up to suggest what is the cause of error. I've successfully gotten a mesh for individual parts, but not for this assembly. I've removed any interference and the pre-check is fine. Any idea what is causing this and how to fix it?
henderh
Hi @julianne_jager,
One thing you can try is checking for geometry errors in the model that could be tripping up the mesher. This can be done using the Inspect > Validate command in the Design workspace. The Validate command is available in direct modeling mode only (i.e. click 'Do not capture Design History' if the Timeline is displaying)
We'd like to investigate why there are no errors returned for the mesh. Could you attach the dataset?
  • File > Export.. > f3d (or f3z) file type
Thank you,
Hugh Henderson
QA Engineer (Fusion Simulation)
julianne_jager
The validate command came up with no issues for the entire assembly. I'll see if I can get you the file. I'm also updating Fusion now, in case that's part of the problem.
julianne_jager
I can't share the dataset due to company policy, but I have found a semblance of a solution. The mesh solves fine and in a reasonable amount of time when I remove all fillets using the Simplify workspace. There are a lot of fillets because the angle iron is modelled using them.
henderh
This is great news you've found a solution. We appreciate the follow up details.
Hugh Henderson
