Mouse wheel zoom not working after last update
niklas.nordahlBSGYC
Message 1 of 29
niklas.nordahlBSGYC
I have the same problem since the last update last week. All of a sudden i need to hold the cmd button to use scroll zoom. Otherwise the model is just panned up and down.
I use Mac and Big Sur 11.2.2
Thank You
Replies (28)
Message 2 of 29
dsouzasujay
Hi @niklas.nordahlBSGYC ,
Can you check the settings in Preferences? is it matching the same settings that you were using before?
Screenshot 2021-03-12 at 8.49.45 AM.pngScreenshot 2021-03-12 at 8.49.45 AM.png
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 29
niklas.nordahlBSGYC
Thank you for your reply Sujay.
I have checked the preferences and the Pan, Zoom... option is set to "Fusion". I have also tried restoring to default and even reinstalled Fusion 360 without success.
I also use Autocad 2021 where the zoom-function works with the scroll wheel.
See screenshot.
Message 4 of 29
TheCADWhisperer
Set to SolidWorks.
Message 5 of 29
niklas.nordahlBSGYC
Hi
I've tried that and all the other app-specific settings. All result in model panning up and down slowly when I roll the mouse wheel.
Does no one else have this problem after the update?
All My other apps still work the same as before last weeks update of Fusion.
Message 6 of 29
dsouzasujay
I can't reproduce this issue on macOS and Win 10.
Can you please record a screencast video of what you are doing by capturing the keyboard and mouse events.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 29
niklas.nordahlBSGYC
Hi Here's the screencast of the issue.
Im using a 3dConnextion wireless cadmouse with cable.
Message 8 of 29
niklas.nordahlBSGYC
Message 9 of 29
dsouzasujay
We have wireless 3dConnextion and a CADmouse with cable.
I will see if we can reproduce this issue on a MacOS.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 10 of 29
dsouzasujay
We were not able use CAD mouse on macOS Big Sur, only mouse movements are working no mouse clicks or scroll was working.
I saw there was an update on 3dconnexion webpage regarding support of CAD mouse.
Can you provide us the macOS version you are on?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 11 of 29
niklas.nordahlBSGYC
Hello
I updated the 3DConnexion software to the latest version, but unfortunately no change. Problem persists.
Just for info I also made a screencast in Autocad 2021 where the zoom works.
I have Mac OS version 11.2.3 (20D91)
and the 3DxWare 10, core version 1.2.0 (192), 3DxWare  version 10.7.0 (3318)
Hope you can find a solution to the problem. I keep mixing up the modifyer keys when I do my modeling and it is quite frustrating.
Best regards
Niklas Nordahl
Message 12 of 29
niklas.nordahlBSGYC
Message 13 of 29
bharamk
Could you please try latest firmware upgrade provided by 3dconnexion version 10.7.0 [3333]
at https://3dconnexion.com/uk/support/faq/beta-driver-for-macos-11-big-sur/
and please download the CAD mouse updates from  https://3dconnexion.com/uk/support/faq/cadmouse-doesnt-click-on-macos-11-0-big-sur/
This should solve your issue.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Message 14 of 29
b5.belgie
I have the same after the update or after trying the new Native trackpad function. i had to restart and than the zoom was gone (mac with apple mouse)
Tried to delete Fusion and did new install but problem stays and the Native trackpad option wont turn off.
Message 15 of 29
b5.belgie
Can i go back to the version before the update?
trying to draw something but when i have to zoom i need to use my trackpad.
This update was not good and i would like to go back to the working version.
Message 16 of 29
RajkumarIlanchelian
@b5.belgie Sorry that you are facing issues with the new track pad experience. To get you moving forward without the new track pad, can you please do the following and see if this unchecks the option?
1. Go to preference -> Uncheck the native trackpad option
2. Apply
3. To the restart select NOT NOW
4. Ok
5. Manually close Fusion 360
6. Start Fusion 360 again
Now does this uncheck the new track pad experience?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 17 of 29
b5.belgie
Tried this 5 times but the "native trackpad" stays checked and mouse zoom still not working 😞
I have to press CMD and than scroll like crazy before it starts to zoom.
Very slow working like this, hope there will be a fix quickly
Message 18 of 29
RajkumarIlanchelian
@b5.belgie Apologies once again. WE are working to address the original track pad issue as a priority. Meanwhile cannot uncheck the Native track pad is having us stumped but we are very closely looking at it. Can you please try one more thing for me. We believe the unchecking not sticking could be a timing thing. So slight variation to the the one I suggested above:
1. Launch Fusion 360
2. Ensure that the refresh in the data panel is not spinning (Wait for it to stop if it is)
3. Go to preference -> Uncheck the native trackpad option
4.  Apply
5. To the restart select NOT NOW
5.  Ok
6. Open a simple design
7. Close the design
8. Make sure that the data panel refresh is not spinning
9. Manually close Fusion 360
10.Start Fusion 360 again
Now does it remain unchecked? If this is not working, I can get on a call with you based on your time zone (or have another person in my team get on a call with you and try to get you back to the previous state while we solve the actual track pad issue).
Apologies and thank you for your patience.
Autodesk Fusion
Join Fusion Insider
Message 19 of 29
b5.belgie
Its working again 🙂 thank you for the support !!
I did the following;
Open preference and check the HighDPIScaling (windows only) box
Apply and oke
Restart Fusion
Open preference again and uncheck the HighDPIScaling (windows only) box
Than restart again
Now the Native trackpad box in unchecked and zoom is working as before
Hope this is useful for others and happy designing.
Greetings from Belgium.
Bart Geldof
Message 20 of 29
RajkumarIlanchelian
@b5.belgie Glad that you are a able to revert it now. We are working to fix the zoom issue you are experiencing as well as the preference issue. We will update here when we have a fix for it.
Autodesk Fusion
Join Fusion Insider
