Export DXF file results enlarged - Student Edition
I have the student version of fusion 360. When I export a drawing (not extruded) as a DXF it enlarges in size when opened in applications. Opening it on a Lone Star plasma table, software is called SheetCam (for setup/G code) and SpitFire to run the machine. I also had a problem when trying to use the DXF feature on a Hurco VM20i CNC knee mill. For the hurco I just redrew the drawing in solidworks and it was fine. As far as the plasma cutter I imported the DXF into Corel draw and that fixed the sizing. Is there something I'm missing? Just went through all the settings. Or is this because its a student edition.
Does it matter if I go to export as DXF or save as DXF?
3D modeling and saving as .stl for 3d printing works fine.
daniel_lyall
Are the units the same in fusion as where you are sending it, like in to in or mm to mm?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
yes
ClintBrown3D
It certainly sounds like you have a units issue. If you can attach your files as an F3Z (Fusion Archive) we can take a look at it for you.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
