Joint drawing error in recent versions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've noticed in recent versions (not sure when it started) that when I click on the name of a joint to drive it, the joint itself draws as a large blocky area rather than the normal thin lines and arrows. Seems to do this whenever the joint is not shown (eyeball icon is de-selected). When its visible, the joint draws properly. Here is a screen shot of what I am talking about, with the joint pointed at by a red arrow I added:
Over on the left side what I had done was right click on the second joint down, Joint Lever Revolute, and select 'drive joint'. If I do the same thing but first make that joint visible, it draws normally. I've noticed this especially if the joint was hidden in the saved project that I opened. Once its made visible, the problem seems to go away.
