Editable documents - text error
jeffhaas
jeffhaas
I think you have an error in the text that explains how many editable documents are used, in the free version.
The top line shows "4 of 10 editable documents", while the first line of the paragraph says "the limit of 4 editable documents".   The impression you get is that you currently can only edit 4 documents, not 10.
This line will change depending on how many documents are currently editable, so it may show 5, 7 or 1 editable Fusion documents.  For example, I made one document read-only, and the popup changed to:
I think this accounts for some of the confusion in user feedback.
  • bug
karina.harper
Autodesk Support
Autodesk Support
Hi @jeffhaas
I don't see this logged internally. I went ahead and logged it as FUS-256178, thanks for reporting.
Cheers,
Karina
Closed-Loop-Bot
We're happy to report this issue has been resolved. Update Fusion to the most recent version to apply the fix. If this update resolved your issue, feel free to click the "Accept Solution" button to help other community members find the answer more easily. If the issue persists after updating, don't hesitate to reach out to us by replying to this thread. We're here to help! Let us know if you need any further assistance!
