Install problems MacOS - Mojave
Message 1 of 23
Getting this error  -
PermissionError: [Errno 1] Operation not permitted: '/Users/Home/Applications/Autodesk Fusion 360.app'
Checked and repaired permissions but still can't install. '
Log file attached.
Replies (22)
Message 2 of 23
ryan.bales
Autodesk Support
Autodesk Support
You might need to go to the security settings and see if there are any errors or prompts in there.
Its similar to this article
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Per...
Ryan Bales
Fusion 360 Product Support
Message 3 of 23
Afraid those solutions did not work for me.
There was no Fusion360 process running in Activity Monitor.
A restart of the system did not solve the problem.
There is no firewall running.
There is no Anti-Virus Software running.
Please advise if possible. Thank you.
Message 4 of 23
ryan.bales
Autodesk Support
Autodesk Support
Is this a shared computer? If so did the other use previously install Fusion 360?
Ryan Bales
Message 5 of 23
It is a shared computer but no other user has installed Fusion 360.
There is no Fusion 360 app in Applications.
Message 6 of 23
ryan.bales
Autodesk Support
Autodesk Support
You mean under here?
"/Users/Home/Applications/Autodesk Fusion 360.app"
Ryan Bales
Message 7 of 23
Yes.
Message 8 of 23
ryan.bales
Autodesk Support
Autodesk Support
Can you look into this directory /Users/(username)/Library/Application Support/Autodesk/webdeploy/production and see if there is a Fusion app and if it launches?
Ryan Bales
Message 9 of 23
There is an alias but when I click it...
"The application "Autodesk Fusion 360" can't be opened"
In a subfolder (with many letters and numbers) there's a 2.38 GB App called "Autodesk Fusion 360" but I get the same error when I click on that as well.
Cheers.
Message 10 of 23
ryan.bales
Autodesk Support
Autodesk Support
THen i think we need to back it way off with a clean uninstall and try again
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Ryan Bales
Message 11 of 23
Yea. OK.....
Ran the cleaner tool and then tried to reinstall...and got the same error message.
Message 12 of 23
ryan.bales
Autodesk Support
Autodesk Support
The only things i can think of are to try creating a new Apple admin user profile, or test a lab install.
Ryan Bales
Message 13 of 23
ryan.bales
Autodesk Support
Autodesk Support
Another thought - if you run the cleanup tool, make sure the directory mentioned is actually emptied. Otherwise its not fully cleaning up- which is highly possible. But its really stating it doesn't have permission to clear that link or it already exists and cannot be removed.
Ryan Bales
Message 14 of 23
OK. I checked it and it looked empty. I deleted the Autodesk folder to be sure, but no joy.
Am I to understand that the Error 1 code I'm getting is in relationship to Alias or to the Program? I've been trying to look at the log to see what it's trying to do and failing.
thanks
Message 15 of 23
andrii.anpilogov
Hi @Anonymous
Could you open a terminal, run "ls -la /Users/Home/Applications" and post its output?
And thanks for sharing the logs!
Regards
Message 16 of 23
total 16
drwx------   5 Home  staff   160 Nov 26  2015 .
drwxrwxrwx@ 47 Home  staff  1504 Oct  9 10:13 ..
-rw-r--r--@  1 Home  staff  6148 Mar 20  2019 .DS_Store
-rw-r--r--@  1 Home  staff     0 May 30  2014 .localized
drwx------@  4 Home  staff   128 Oct 21  2018 Chrome Apps.localized
Message 17 of 23
andrii.anpilogov
Thanks. We can't reproduce the issue but it's definitely a bug and we'll look into this.
Could we contact with you directly for helping us with deeper investigation of the issue?
Message 18 of 23
Sure. You can contact me.
Message 19 of 23
Since no one got back to me...I decided to try it again and it had the same problem, but this time...I did find the Fusion app in the Library folder and it launched. What should I do next.?
Message 20 of 23
Following up on this after a few months. was there ever any kind of solution to my install problem?
