Iges file not opend
Iges file not opend
IDIMITRIOUD883D
Message 1 of 10
Iges file not opend
IDIMITRIOUD883D
I 'm trying to open an .igs file that i used to able earlier but is not possible now .The file is not damaged and it can be opened in other cad program. The file can be opend only when i change it to .dxf.
Thank you
Best regards
Accepted solutions (3)
Replies (9)
Message 2 of 10
RajkumarIlanchelian
@IDIMITRIOUD883D Is this specific to only this one iges file or ANY files that you have? Also, would it be possible to share this file here?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 10
IDIMITRIOUD883D
When i tried to upload it here, i received the msg "The file type (.igs) is not supported" see below. So i send it as a .txt file.
Thank you
Message 4 of 10
RajkumarIlanchelian
You can zip and attach it here too.
Autodesk Fusion
Join Fusion Insider
Message 5 of 10
IDIMITRIOUD883D
I also send this .jpg from IGS viewer.
Message 6 of 10
IDIMITRIOUD883D
Ok i sent the .rar file.
Thank you again
Best Regards
Message 7 of 10
IDIMITRIOUD883D
I tried some others with the same results.
Message 8 of 10
jhackney1972
I downloaded your RAR file, expanded it and opened it in Autodesk Inventor.  The file opens just fine in Fusion 360 as well.  The problem I see is the file is empty, there is nothing in it.
John Hackney, Retired
Message 9 of 10
TrippyLighting
Fusion 360 cannot do anything with wireframe geometry (curves). It only imports 3D geometry (surfaces or solids).
That's likely the reason why DXF seems to work, yet when @jhackney1972 can open the .igs file, it is empty in Fusion 360.
Message 10 of 10
IDIMITRIOUD883D
This type of file with the same data was working in earlier versions. I mean iges file is iges file and the code for line is still the same (110). Also coordinates are (x,y,z) .  Perhaps files like this are not permitted any more?
Thank you.
