saves get stuck I repair fusion or reload fusion it works once then stops working
oneturboneeded
Message 1 of 9
oneturboneeded
saves get stuck in uploads. I repair fusion or reload fusion it works once then stops working. there is never a button to clear cache also.
Replies (8)
Message 2 of 9
RajkumarIlanchelian
@oneturboneeded Sounds more like a network but can you please do the below?
1. Shutdown Fusion and restart your machine
2. Restart your router
See if this helps.
If this does not then go to
1. Add/Remove programs
2. Select Fusion 360
3.Select Modify
This will launch the Fusion service utility
4. Run the "gather system info"
5. Please attach the diagnostics logs.zip
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
oneturboneeded
I tried and i just get sorry could not complete action requested
Message 4 of 9
oneturboneeded
but looks like there still attached.
Message 5 of 9
RajkumarIlanchelian
@oneturboneeded Thanks for the logs. Will take a look. I assume the restart of your router did not work?
Also one more thing if you can try. Connect to your say cellphone hotspot and see if that helps? Essentially a different network.
I am trying to eliminate network here.
Autodesk Fusion
Join Fusion Insider
Message 6 of 9
RajkumarIlanchelian
Certainly see the errors in the logs. Am consulting with our engineering team on this.
Autodesk Fusion
Join Fusion Insider
Message 7 of 9
oneturboneeded
I switched networks but same router we have a 2.4 and 5 gig so I changed from the 2.5 to 5. will this make a difference? I cannot set up a hot spot here bad cell range.
Message 8 of 9
pierre-yves.monarque
Hi @oneturboneeded
Can you confirm I understand the problematic workflow correctly:
1 You open your assembly
2 You save -> it succeeds
3 You save again -> You see job failing in the job status ?
4 You repair or clear Fusion cache, restart and reopen the assembly
5 Save works once and upload fails again on subsequent saves ?
Sorry for the inconvenience. Having more informations will speed up investigation.
If there is a possibility to jump on a call to investigate further, let know what would be a good time.
Regards
Pierre-Yves Monarque
Autodesk Fusion 360 Team
Message 9 of 9
Hi @oneturboneeded
One additional comment, there has been some modifications in latest fusion update that might solve the issue you are facing. Could you update fusion to latest build (2.0.17244) and try the problematic workflow ?
