G-Code shows z-moves instead of using G73 for chip breaking
jweingartX8ZP2
jweingartX8ZP2
Hello, I'm new to using Autodesk Fusion, and I'm using it to drill, tap, and mill a few surfaces on a piece of extruded heatsink. The drilling operations all have 'Chip Breaking-partial retract' as its Cycle Type with 0.05 in as the Pecking Depth, Minimum Pecking Depth. Pecking Depth Reduction is 0 in and Accumulated Pecking Depth is 0.525 in. While looking at the G-Code it generated, I saw that the first drilling operation shows the chipping as z-moves instead of using G73 like the others. I wanted to know why it did this for the first operation and not the others, and if there was something I needed to do so that it always uses G73?
(T1 D=0.5 CR=0. TAPER=118DEG - ZMIN=-0.5252 - DRILL)
(T2 D=0.125 CR=0. TAPER=118DEG - ZMIN=-0.4126 - DRILL)
(T3 D=0.187 CR=0. TAPER=118DEG - ZMIN=-0.4312 - DRILL)
(T4 D=0.138 CR=0. - ZMIN=-0.375 - RIGHT HAND TAP)
(T6 D=1. CR=0. TAPER=90DEG - ZMIN=-0.248 - COUNTERSINK)
(T7 D=2. CR=0. - ZMIN=-0.015 - FACE MILL)
N10 G90 G94 G17
N15 G20
N20 G28 G91 Z0.
N25 G90
(.50 DIA HOLES)
N30 T1 M6
N35 S5000 M3
N40 G4 P36
N45 G90 G94 G17
N50 M8
N55 G0 E1 X2. Y0.0004
N60 G43 Z0.6 H1
N65 Z0.2
N70 Z0.08
N75 G1 Z-0.05 F40.
N80 G0 Z0.
N85 G1 Z-0.1 F40.
N90 G0 Z-0.05
N95 G1 Z-0.15 F40.
N100 G0 Z-0.1
N105 G1 Z-0.2 F40.
N110 G0 Z-0.15
N115 G1 Z-0.25 F40.
N120 G0 Z-0.2
N125 G1 Z-0.3 F40.
N130 G0 Z-0.25
N135 G1 Z-0.35 F40.
N140 G0 Z-0.3
N145 G1 Z-0.4 F40.
N150 G0 Z-0.35
N155 G1 Z-0.45 F40.
N160 G0 Z-0.4
N165 G1 Z-0.5 F40.
N170 G0 Z-0.45
N175 G1 Z-0.5252 F40.
N180 G0 Z0.2
N185 X4.75
N190 Z0.08
N195 G1 Z-0.05 F40.
N200 G0 Z0.
N205 G1 Z-0.1 F40.
N210 G0 Z-0.05
N215 G1 Z-0.15 F40.
N220 G0 Z-0.1
N225 G1 Z-0.2 F40.
N230 G0 Z-0.15
N235 G1 Z-0.25 F40.
N240 G0 Z-0.2
N245 G1 Z-0.3 F40.
N250 G0 Z-0.25
N255 G1 Z-0.35 F40.
N260 G0 Z-0.3
N265 G1 Z-0.4 F40.
N270 G0 Z-0.35
N275 G1 Z-0.45 F40.
N280 G0 Z-0.4
N285 G1 Z-0.5 F40.
N290 G0 Z-0.45
N295 G1 Z-0.5252 F40.
N300 G0 Z0.2
N305 X9.25
N310 Z0.08
N315 G1 Z-0.05 F40.
N320 G0 Z0.
N325 G1 Z-0.1 F40.
N330 G0 Z-0.05
N335 G1 Z-0.15 F40.
N340 G0 Z-0.1
N345 G1 Z-0.2 F40.
N350 G0 Z-0.15
N355 G1 Z-0.25 F40.
N360 G0 Z-0.2
N365 G1 Z-0.3 F40.
N370 G0 Z-0.25
N375 G1 Z-0.35 F40.
N380 G0 Z-0.3
N385 G1 Z-0.4 F40.
N390 G0 Z-0.35
N395 G1 Z-0.45 F40.
N400 G0 Z-0.4
N405 G1 Z-0.5 F40.
N410 G0 Z-0.45
N415 G1 Z-0.5252 F40.
N420 G0 Z0.2
N425 X12.
N430 Z0.08
N435 G1 Z-0.05 F40.
N440 G0 Z0.
N445 G1 Z-0.1 F40.
N450 G0 Z-0.05
N455 G1 Z-0.15 F40.
N460 G0 Z-0.1
N465 G1 Z-0.2 F40.
N470 G0 Z-0.15
N475 G1 Z-0.25 F40.
N480 G0 Z-0.2
N485 G1 Z-0.3 F40.
N490 G0 Z-0.25
N495 G1 Z-0.35 F40.
N500 G0 Z-0.3
N505 G1 Z-0.4 F40.
N510 G0 Z-0.35
N515 G1 Z-0.45 F40.
N520 G0 Z-0.4
N525 G1 Z-0.5 F40.
N530 G0 Z-0.45
N535 G1 Z-0.5252 F40.
N540 G0 Z0.2
N545 X16.5
N550 Z0.08
N555 G1 Z-0.05 F40.
N560 G0 Z0.
N565 G1 Z-0.1 F40.
N570 G0 Z-0.05
N575 G1 Z-0.15 F40.
N580 G0 Z-0.1
N585 G1 Z-0.2 F40.
N590 G0 Z-0.15
N595 G1 Z-0.25 F40.
N600 G0 Z-0.2
N605 G1 Z-0.3 F40.
N610 G0 Z-0.25
N615 G1 Z-0.35 F40.
N620 G0 Z-0.3
N625 G1 Z-0.4 F40.
N630 G0 Z-0.35
N635 G1 Z-0.45 F40.
N640 G0 Z-0.4
N645 G1 Z-0.5 F40.
N650 G0 Z-0.45
N655 G1 Z-0.5252 F40.
N660 G0 Z0.2
N665 X19.25
N670 Z0.08
N675 G1 Z-0.05 F40.
N680 G0 Z0.
N685 G1 Z-0.1 F40.
N690 G0 Z-0.05
N695 G1 Z-0.15 F40.
N700 G0 Z-0.1
N705 G1 Z-0.2 F40.
N710 G0 Z-0.15
N715 G1 Z-0.25 F40.
N720 G0 Z-0.2
N725 G1 Z-0.3 F40.
N730 G0 Z-0.25
N735 G1 Z-0.35 F40.
N740 G0 Z-0.3
N745 G1 Z-0.4 F40.
N750 G0 Z-0.35
N755 G1 Z-0.45 F40.
N760 G0 Z-0.4
N765 G1 Z-0.5 F40.
N770 G0 Z-0.45
N775 G1 Z-0.5252 F40.
N780 G0 Z0.2
N785 Z0.6
N790 M5
N795 G28 G91 Z0.
N800 G90
(.125 DIA HOLES 36)
N805 M9
N810 M1
N815 T2 M6
N820 S5000 M3
N825 G90 G94 G17
N830 M8
N835 G0 E1 X17.875 Y0.0004
N840 G43 Z0.6 H2
N845 Z0.2
N850 G98 G73 X17.875 Y0.0004 Z-0.4126 R0+0.185 Q0.05 P0.05 F40.
N855 X10.625
N860 G80
N865 G1 X5.875 Y0.4694 Z0.2 F100.
N870 G0
N875 G98 G73 X5.875 Y0.4694 Z-0.4126 R0+0.2 Q0.05 P0.05 F40.
N880 Y-0.4686
N885 G80
N890 G1 X3.375 Y0.0004 Z0.2 F100.
N895 G0
N900 G98 G73 X3.375 Y0.0004 Z-0.4126 R0+0.185 Q0.05 P0.05 F40.
N905 G80
N910 Z0.6
N915 M5
N920 G28 G91 Z0.
N925 G90
(.187 DIA HOLES)
N930 M9
N935 M1
N940 T3 M6
N945 S5000 M3
N950 G90 G94 G17
N955 M8
N960 G0 E1 X0.5 Y0.0004
N965 G43 Z0.6 H3
N970 Z0.2
N975 G98 G73 X0.5 Y0.0004 Z-0.4312 R0+0.2 Q0.05 P0.05 F40.
N980 X7.
N985 X14.25
N990 X20.75
N995 G80
N1000 Z0.6
N1005 M5
N1010 G28 G91 Z0.
N1015 G90
(36 TAP)
N1020 M9
N1025 M1
N1030 T4 M6
N1035 S500 M5
N1040 G90 G94 G17
N1045 M8
N1050 G84.2
N1055 G0 E1 X5.875 Y0.4694
N1060 G43 Z0.9 H4
N1065 Z0.5
N1070 G98 G84.1 X5.875 Y0.4694 Z-0.375 R0+0.2 S500 F15.625
N1075 Y-0.4686
N1080 G80
N1085 Z0.9
N1090 M5
N1095 G28 G91 Z0.
N1100 G90
(CSINK)
N1105 M9
N1110 M1
N1115 T6 M6
N1120 S5000 M3
N1125 G90 G94 G17
N1130 M8
N1135 G0 E1 X0.5 Y0.0004
N1140 G43 Z0.6 H6
N1145 Z0.2
N1150 G98 G81 X0.5 Y0.0004 Z-0.123 R0+0.2 F13.33
N1155 G80
N1160 G1 X2. Z0.2 F100.
N1165 G0
N1170 G98 G81 X2. Y0.0004 Z-0.248 R0+0.2 F13.33
N1175 X4.75
N1180 G80
N1185 G1 X7. Z0.2 F100.
N1190 G0
N1195 G98 G81 X7. Y0.0004 Z-0.123 R0+0.2 F13.33
N1200 G80
N1205 G1 X9.25 Z0.2 F100.
N1210 G0
N1215 G98 G81 X9.25 Y0.0004 Z-0.248 R0+0.2 F13.33
N1220 X12.
N1225 G80
N1230 G1 X14.25 Z0.2 F100.
N1235 G0
N1240 G98 G81 X14.25 Y0.0004 Z-0.123 R0+0.2 F13.33
N1245 G80
N1250 G1 X16.5 Z0.2 F100.
N1255 G0
N1260 G98 G81 X16.5 Y0.0004 Z-0.248 R0+0.2 F13.33
N1265 X19.25
N1270 G80
N1275 G1 X20.75 Z0.2 F100.
N1280 G0
N1285 G98 G81 X20.75 Y0.0004 Z-0.123 R0+0.2 F13.33
N1290 G80
N1295 Z0.6
N1300 M5
N1305 G28 G91 Z0.
N1310 G90
(MILLING)
N1315 M9
N1320 M1
N1325 T7 M6
N1330 S2000 M3
N1335 G90 G94 G17
N1340 M8
N1345 G0 E1 X3.375 Y2.1625
N1350 G43 Z0.6 H7
N1355 Z0.2
N1360 G1 Z-0.015 F13.33
N1365 Y2.0629 F40.
N1370 Y-2.0629
N1375 G19 G2 Y-2.2629 Z0.185 K0.2
N1380 G0 Z0.2
N1385 G1 X10.625 Y-2.1625 F100.
N1390 Z-0.015 F13.33
N1395 Y-2.0629 F40.
N1400 Y2.0629
N1405 G3 Y2.2629 Z0.185 K0.2
N1410 G0 Z0.2
N1415 G1 X17.875 Y2.1625 F100.
N1420 Z-0.015 F13.33
N1425 Y2.0629 F40.
N1430 Y-2.0629
N1435 G2 Y-2.2629 Z0.185 K0.2
N1440 G0 Z0.6
N1445 G17
N1450 M9
N1455 G28 G91 Z0.
N1460 G90
N1465 G0
N1470 G53 X0. Y0.
N1475 M30
serge.quiblier
Hi @jweingartX8ZP2 ,
next time, please avoid to post the full nc program in the body of the message.
Send it as an attachement instead.
Regarding your issue, can you please specify the post you are using?
In a general manner, if we have a long hand output, it's either because the cycle is not supported on the controller, or you are using a set of features that is not allowed by the controller cycle.
For example, some cycles does not support dwell, others don't support the accumulated peck depth function.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
megamechasloth
I'll avoid posting the full nc program in the future, and I'm using the Fadal post provided in the fusion library. As for a long hand output or the cycle isn't supported on the controller, I'm not sure if that would be an issue. I'm just drilling holes, and the only difference between the operations is drill bit diameter and the number of holes.
serge.quiblier
Hi @megamechasloth
I looked at the fadal post, and here it is:
    case "chip-breaking":
      if ((cycle.accumulatedDepth < cycle.depth) || (dwell > 0)) {
        expandCyclePoint(x, y, z);
      } else {
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73),
          getCommonCycle(x, y, z, cycle.retract),
          (((cycle.incrementalDepthReduction > 0) ? "I" : "Q") + xyzFormat.format(cycle.incrementalDepth)),
          conditional(cycle.incrementalDepthReduction > 0, "J" + xyzFormat.format(cycle.incrementalDepthReduction)),
          conditional(cycle.incrementalDepthReduction > 0, "K" + xyzFormat.format(cycle.minimumIncrementalDepth)),
          conditional(cycle.chipBreakDistance > 0, "P" + xyzFormat.format(cycle.chipBreakDistance)), // optional P value
          feedOutput.format(F)
      break;
If we set a dwell on the chip breaking operation, OR if the accumulated peck depth is smaller than the total hole depth, then the output will be generated using G0/G1 moves.
Example of the parameters to verify:
If the red framed value is smaller than the hole depth (in another tab, unfortunately), or a dwell is defined in the blue framed editbox, then the cycle is expanded.
That the logic implemented in the post.
If you want a canned cycles, these are culprit you need to fix.
Regards
Serge.Q
cam.autodesk.com
megamechasloth
The Accumulated Pecking Depth seems to have been the problem. Thank you!
serge.quiblier
Adding some tags to the thread for documentation.
Serge.Q
cam.autodesk.com
