Message 1 of 23
- Mute
- Permalink
- Report
Updated to current version ( late Sept 2024 ) and running under OS win 10. Model exported as an stl file ok yesterday. Fusion kept freezing when attempting to resize a rectangular block today, but repositioned and it then resized ok. I then trimmed ( cut away ) two curves and the model won't now export as an stl file. Rebooted, logged out and then back in. Can save adjustments and export as an f3d file, but once I try to export as an stl file, Fusion just keeps freezing again and again. I guess it's the adjusted model that's the issue, rather than a fusion issue. In the attached f3d file, body56 is the model I'm having the problem with. Thanks.
